sneakthief
Posted: Mon Apr 23, 2007 12:38 pm Post subject:
circuit to scale 0-10v to 0-5v? |
pardon me if this is a rudimentary question, but is there a simple way to scale a voltage source of 0-10v to 0-5v?
i've built a lovely MIDIbox CV midi-cv converter ( http://www.ucapps.de/midibox_cv.html ) and am in the process of adding CV-input functionality. unfortunately the analog inputs of this project only accept 0-5v.
once i get the input voltage it scaled down, the software will then convert the voltage to a note number - and with the help of a few ASM gurus, we're going to create a scale-quantizer and harmonizer.
Info: the MIDIbox CV supports 8 CV+Gate & sync out and can be built for as low as $60-70 US with a little help from microchip & analog devices  _________________ Sneak-Thief - raw electrofunk |
etaoin
Joined: Jun 30, 2005 Posts: 761 Location: Utrecht, NL
Posted: Mon Apr 23, 2007 12:55 pm Post subject:
Re: circuit to scale 0-10v to 0-5v? |
sneakthief wrote: | pardon me if this is a rudimentary question, but is there a simple way to scale a voltage source of 0-10v to 0-5v? |
Use a voltage divider made from two resistors...
Code: |
signal in --- resistor ---+--- resistor --- ground
signal out
I gues 100k resistors would do fine. |
sneakthief
Thomas Henry
Joined: Mar 25, 2007 Posts: 298 Location: Southern Minnesota
Posted: Mon Apr 23, 2007 6:20 pm Post subject:
The divider takes care of the voltage levels, as explained above, but there's more to think about.
You should also consider the output impedance. According to the Electronotes standard, the output Z of most synth circuits should be 1K. This is easy to arrange here. Besides computing the divider voltages mentioned above, arrange for the parallel resistance of the two resistors to be equal to the desired Z.
For this case, we want 0 to +10V to go to 0 to +5V, with a output Z of 1K (common for Electronotes circuits). Choosing both resistors to be 2K gives the required voltage reduction (10V max to 5V max), and in parallel they are 1K, a good impedance to drive other modules without worrying about shorted outputs.
My rule of thumb has always been: design a circuit to (a) be elegant, and (b) not burn up or cause other modules to burn up, no matter how stupid the operator may be.
Thomas Henry |
sohcahtoa
Posted: Mon Apr 23, 2007 9:52 pm Post subject:
Thomas,
I don't see any parallel resistors in that circuit, are you talking in reference to some other circuit?
Furthermore what is "Electronotes" ? |
etaoin
Posted: Mon Apr 23, 2007 11:18 pm Post subject:
Quote: |
You should also consider the output impedance. According to the Electronotes standard, the output Z of most synth circuits should be 1K. |
Quite true. I was just thinking the other way round, i.e. scaling the input of the target circuit and not the output of the MIDI-CV. Especially since 0-10V is a pretty common range for control voltages I'd just keep that like it is. |
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
EdisonRex
Audio files: 172
Posted: Tue Apr 24, 2007 12:20 am Post subject:
sohcahtoa wrote: | Thomas,
http://electronotes.netfirms.com/
Bernie has been publishing since the early 70s. I grew up collecting Electronotes, and built my first and second synthesizers using circuits from Electronotes. The Musical Engineer's Handbook is a classic. _________________ Garret: It's so retro.
Posted: Tue Apr 24, 2007 3:00 am Post subject:
I am also having problems with the parallel resistance idea. They are in series aren't they? _________________ What makes a space ours, is what we put there, and what we do there. |
Joined: Apr 03, 2004 Posts: 24461 Location: The Netherlands, Enschede
Audio files: 297
Posted: Tue Apr 24, 2007 3:14 am Post subject:
Uncle Krunkus wrote: | I am also having problems with the parallel resistance idea. They are in series aren't they? |
For the impedance calculation the resistors can be considered to be in parallel. This is because the leftmost (usually drawn topmost) resistor is assumed to be driven from a low (zero) impedance circuit (voltage source). This low impedance is referenced to ground. The other resistor is directly conncted to ground, so from that perspective they seem to be parallel,
Still the resistors are in series indeed  _________________ Jan
sneakthief
Posted: Tue Apr 24, 2007 6:53 am Post subject:
many thanks to everyone for the input!
re. Electronotes - In 1975 the author of Electronotes, Bernie Hutchins, wrote a book called the "Musical Engineer's Handbook" - both the Electronotes series and this book have basically been the reference and inspiration for a good portion of todays modular synths.
AFAIK Don Buchla, Bob Moog and Serge Tcherepnin were all subscribers to Electronotes and were definitely inspired by the schematics and/or contributed their own to the magazine.
I would even go so far to say that most current modular manufacturers have "borrowed" designs from the Electronotes series ; )
ps. Mr. Henry, it's delightful to have you here  _________________ Sneak-Thief - raw electrofunk |
Posted: Tue Apr 24, 2007 8:10 am Post subject:
Thanks Jan,
suddenly it all makes sense!
I think.  _________________ What makes a space ours, is what we put there, and what we do there. |
Thomas Henry
Posted: Tue Apr 24, 2007 10:17 am Post subject:
sohcahtoa wrote: |
No. The two resistors are seen as parallel by the circuit being driven by the tie-point of the resistors.
It's easy to set up a spread sheet to compute good values showing various combinations of impedances and voltage levels.
Hope this helps,
Thomas Henry |
Scott Stites
Audio files: 96
Posted: Tue Apr 24, 2007 10:31 am Post subject:
Mmmmmmyep. Actually, one of my favorite Thomas Henry tricks is to get a 1K impedance out of a 15V -> 5V divider. The signal passes through a 3K resistor with a 1.5K resistor to ground. Violin! - you get a 5V output out of 15V and it's a 1K output impedance. Very handy for converting a comparator signal that rails at +15V to a +5V signal (say an Electronotes standard +5V gate or trigger). Learned that one from the Potpourri module in "Build a Better Music Synthesizer".
What's that? You use 10V gates and triggers? No problem, swap the two resitors around and Viola! - you get a 10V signal with an output impedance that is still 1K.
The above explains the output resistors on the Klee gate bus, and the note about the 10V gates/triggers.
Scott |
