today> Twyndyllyngs Chez Mosc
Frac-rack Panels
Page 1 of 2 [29 Posts]
crazeydazey
PostPosted: Wed Jun 06, 2007 2:26 am    Post subject: Frac-rack Panels Reply with quote  Mark this post and the followings unread
Could anyone tell me where I get blank panels from, I assume they can be bought, or do I have to buy a sheet steel and cut it to size (I hope not you can have someones eye out with that stuff).
I hear frac-rack mentioned a lot but after a google search found nothing for buying blank panels..
please help..
Daz
bugbrand
PostPosted: Wed Jun 06, 2007 3:05 am    Post subject: Reply with quote  Mark this post and the followings unread
www.paia.com - though I think the price has risen (quite a bit) recently.
And maybe www.blacet.com too.
http://www.bugbrand.co.uk
crazeydazey
PostPosted: Wed Jun 06, 2007 3:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy great stuf, found em on paia and they are still not a bad price, excellent.
thnx bugbrand
for my next trick I need to find out the cheapest way to get my panel designs on to the panels (I thought about screen printing, but that doesn't actually work out that cheap).
PostPosted: Wed Jun 06, 2007 3:29 am    Post subject: Reply with quote  Mark this post and the followings unread
another possibility would be to let schaeffer make them for you...
crazeydazey
PostPosted: Wed Jun 06, 2007 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I've looked into that, they seem a little too expensive, and I haven't quite got the hang of the software yet Embarassed , I like to use photoshop for designing them, unless there is an import function..that would be nice.
PostPosted: Wed Jun 06, 2007 3:44 am    Post subject: Reply with quote  Mark this post and the followings unread
no import function, only hpgl files could be imported... Sad
doctorvague
PostPosted: Wed Jun 06, 2007 4:33 am    Post subject: Reply with quote  Mark this post and the followings unread
thnx bugbrand
I bought some of these PAIA panels recently and the finish was horrible. The double wide ones were purple, the singles were black and they all had various gouges in them - neither side was usable IMO. They're also **WAY thicker than Blacet panels and look like crap in the same rack with the Blacet's IMO. They are heavier metal though if that's what you want.
Unfortunately the ones Blacet sells have a bunch of holes predrilled that you may or may not want. I wish he just sold plain anodized panels with mounting holes only.
I had some T6 aluminum cut at a local metal place for real cheap- 10 singles and 10 doubles for $15 US. There are other threads about how to deal with the panel fronts from there.
Phil
doctorvague's youtube channel
crazeydazey
PostPosted: Wed Jun 06, 2007 4:59 am    Post subject: Reply with quote  Mark this post and the followings unread
thnx doctorvague, I think I may look locally and see about getting some cut (i just don't fancy cutting it myself)
and I will look through the forum for some ideas on putting my layout onto the panels.
I would like to use schaeffer, but I find designing the panels much easier in photoshop, though going back to my earlier comment about them been too expensive, I think by the time I've spent momey on what ever method I use to make the panels, I bet I'm not far off that cost anyway so I might try and get my head round the Front panel designer and see what happens.
ps drv I've just watched your video on your for the DIY peoples post...
It's mental (in a nice way)
PostPosted: Wed Jun 06, 2007 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
there are three kind of things who make schaeffer panels expensive: color in-fill of the engravings, graphics (lines, squares and such) and text objects. so here are three ideas how to lower cost:
1) use black anodized panels (which you will probably do anyway because of frac rack) and don't in-fill the engravings - that will decrease the cost dramatically
2) use hpgl for scales, symbols, logos and all more versatile graphics stuff
3) use text in columns: if you have designators in columns don't create a text object for each. create one text object and use paragraph breaks (adjust line space according to your grid and font size).
BTW on the edit/settings/general tab you can set the editor to the inch-system which would be helpful for frac rack (at blacet.com you will find the measurements for frac rack panels)
crazeydazey
PostPosted: Wed Jun 06, 2007 5:37 am    Post subject: Reply with quote  Mark this post and the followings unread
cheers fonik
I don't know what hpgl is though, I've only just started playing with front panel designer.. sorry for been dumb Embarassed
PostPosted: Wed Jun 06, 2007 5:43 am    Post subject: Reply with quote  Mark this post and the followings unread
crazeydazey wrote:
cheers fonik
hpgl is an old hewlett packard plotter command file format. it was designed for these old pencil plotters and tell the plotter when to move where... so it's ideal for engraving machines too. photoshop may have an export filter? you will be able to export lines only... so a filled plain will have to consist of multple lines in parallel (corel draw provides tools to do that for you, i don't know about photoshop).
crazeydazey
PostPosted: Wed Jun 06, 2007 5:50 am    Post subject: Reply with quote  Mark this post and the followings unread
cheers again..
I'll look into hpgl and photoshop (i'm sure there will be something out there somewhere)
Also I suppose if I don't fill in the engraving I suppose I could paint it myself (my look tacky, but I suppose I'll find that out with trial and error)
PostPosted: Wed Jun 06, 2007 5:57 am    Post subject: Reply with quote  Mark this post and the followings unread
i am waiting for an answer to an email i sent today. at the german modular meeting the guy told me he had done that for a company with a special crayon...
crazeydazey
PostPosted: Wed Jun 06, 2007 5:59 am    Post subject: Reply with quote  Mark this post and the followings unread
cool you'll have to let me know what happens.. Very Happy
doctorvague
PostPosted: Wed Jun 06, 2007 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
This is my first attempt at a front panel design. I use Adobe Illustrator myself because I'm comfortable with it.
The knobs are just setting on the front panel. It looks better than the photo shows, but inkjet printing on paper just won't get black enough.
I want to get some IdMark for the front panels -
I'd recommend reading this thread if you haven't already:
http://www.electro-music.com/forum/topic-17398-25.html&postdays=0&postorder=asc&highlight=idmark
HTH
Phil
Wild Zebra
PostPosted: Wed Jun 06, 2007 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks good dr. I'll have to take your advice going to a machine shop. In my first attempts I've been using plexiglass, as there is a huge box at work at my disposal, but when it's gone. Diggin your quote, I just can't quite get enough of Don.
"your stripes are killer bro"
amos_joseph
PostPosted: Wed Jun 06, 2007 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I've been using ID-Mark for about a year now and I absolutely love the stuff. I initially bought it just to do panels for my modular, but I've been using it for guitar pedals and other electronics projects with excellent results.
Here's my latest ID-Mark creation (a MIDI-sync device for LSDJ)
doctorvague
PostPosted: Wed Jun 06, 2007 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Great job dude!!
I'm ordering some ID-Mark today. Perfect for my needs.
Phil
fluxmonkey
PostPosted: Wed Jun 06, 2007 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
crazeydazey wrote:
cheers again..
Photoshop is raster-based (bitmapped images); HPGL is vector-based... pretty much, never the twain shall meet.
i use a drawing program (freehand or illustrator) to lay out most of my panels, print to paper and then spray mount them to drilled panels, w/ either plastic laminate or sprayed clearcoat on top to protect them. functional cheap and fast.
recently i've done a few more FPD panels... following Fonik's suggestions helps keep the cost down somewhat... biggest drawback for me is the turnaround time... i like instant gratification. plus, i always seem to make one little mistake.
pictures, and some sample FPD files, here
bbob
crazeydazey
PostPosted: Thu Jun 07, 2007 1:07 am    Post subject: Reply with quote  Mark this post and the followings unread
the ID Mark looks pretty cool, but it just looks they do letters, so I guess you couldn't do the dials???
I also like bbobs idea.
I've got a lot of good ideas from this post, thanks guys.. Very Happy
doctorvague
PostPosted: Thu Jun 07, 2007 3:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the site I would definitely have a look at:
http://www.sdiy.org/xyzzy/panels/
It appears you can certainly do any graphics you want with ID-Mark including ticks, etc depending on things like printer resolution and print quality of course.
See the above note about Raster vs vector above e.g. Photoshop vs Illustrator also.
Phil
crazeydazey
PostPosted: Thu Jun 07, 2007 4:42 am    Post subject: Reply with quote  Mark this post and the followings unread
your right, this is what I was looking at..
different thing same name.
PostPosted: Sun Jun 24, 2007 10:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
eventually i got the link for this fill-in colors:
http://www.micro-tools.com/Merchant2/merchant.mvc?LTPLanguage=EN&Screen=PROD&Product_Code=LS-KIT&Store_Code=MTE
crazeydazey
PostPosted: Mon Jun 25, 2007 1:13 am    Post subject: Reply with quote  Mark this post and the followings unread
wow, that looks pretty cool.
You'll have to let me know the results..
PostPosted: Mon Jun 25, 2007 2:01 am    Post subject: Reply with quote  Mark this post and the followings unread
i ordered some colors today. since microtools are located in germany i should be able to post some pictures end of this week...
