Envelope follower with SndBuf not working
Page 1 of 1 [7 Posts]
hanez
PostPosted: Thu Jul 05, 2007 3:38 am    Post subject: Envelope follower with SndBuf not working
Subject description: Gain.op set to 3 (multiplication) yields negative output when used with SndBuf
hi,
i needed an envelope follower. i found one under /examples/deep -> follower.ck, which follows the adc. it works. it goes like this:
Code:
// patch
adc => Gain g => OnePole p => blackhole;
// square the input
adc => g;
// multiply
3 => g.op;
// set pole position
0.9999 => p.pole;
// loop on
while( true ) {
    <<< g.last() >>>;
    if( p.last() > 0.1 )
        <<< "BANG!!" >>>;
    0.1::second => now;
g.last() is always positive
but when i change it to follow a SndBuf instead of the adc the output of g sometimes is negative, which is not logical because a real number squared is alway positive. my code goes like this:
Code:
// patch
SndBuf buf1 => Gain g => OnePole p => blackhole;
// square the input
buf1 => g;
"c:/chuckmeup/somefile.wav" => buf1.read;
// multiply
3 => g.op;
0.9999 => p.pole;
// loop on
while( true ) {
    <<< g.last() >>>;
        <<< "BANG!!" >>>;
    0.1::second => now;
g.last() is positive AND NEGATIVE!
so whats wrong here?
thank you
Hannes
kijjaz
PostPosted: Thu Jul 05, 2007 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm.. Interesting! I'm gonna test with some wav right away. Exclamation
kijjaz
PostPosted: Thu Jul 05, 2007 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Ahh. I know what happened now.
Rechucking ..
(for example .. a => b;
and then a => b; again after that)
Works just like only a single chucking.
So your SndBuf buf1 => Gain g ..
and then buf1 => g again
Only mean one "buf1 => g"
I tried this and it did the multiplication correctly:
Routing buf1 to another dummy gain..
Let's try buf1 => Gain buf1dummy => g;
instead.
That'd work like two input sources into g.
^_^
chuckles
PostPosted: Thu Jul 05, 2007 3:38 pm    Post subject: Well, here's one way you might get around it... Reply with quote  Mark this post and the followings unread
Here's what seemed to work for me:
Code:
SndBuf buf1 => FullRect f => Gain g => OnePole p => blackhole;
FullRect and HalfRect aren't documented very well at present (i.e., essentially not at all!) but I just figured it couldn't hurt to try.
ChucK reminds me of Perl sometimes with the "T>1W2DI" philosophy ("There's More Than One Way To Do It")
Maybe the example with two adcs => to a UG works since adcs are different than SndBufs: i.e., they're "active" during the loop: whereas once you've read a file into a SndBuf, it's a static object.
But I still don't quite understand the point of the .op options. What exactly does it mean to multiply the inputs of a UG? Can someone give another example where that works (besides follower.ck)?
...r...
kijjaz
PostPosted: Thu Jul 05, 2007 5:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
chuckles: Hmm..
using FullRect (or even HalfRect)
is also useful in this suituation
although it has a specific quality.
i guess squaring this kind of data is quite poppular in analysing statistically,
but they all have different characters.
i am thinking about RMS vs PEAK value of the loudness hmmm..
and i don't know how to explain lolol.
chuckles: Oh..
the Gain .op function is like this:
by default, it adds all the input signal..
for example:
signal1 => Gain g;
signal2 => g;
signal3 => g;
g will has output just like the sum of signal1, 2, 3 combined..
this is basic.
this default mode can be set by setting the gain's .op to 1
(for example, 1 => g.op; )
Code:
Step s1, s2, s3; // prepare signals to connect to Gain
Gain g => blackhole; // prepare Gain (and force calculation with blackhole)
// 1 => g.op; is default: for normal signal summation
// connect all s to g
s1 => g;
s2 => g;
s3 => g;
0.1 => s1.next;
0.2 => s2.next;
0.4 => s3.next;
samp => now; // time passes..
<<< g.last() >>>;
result: 0.700000 :(float)
(correctly, equals to .1 + .2 + .4)
now with op = 2, the first signal will be the primary signal,
but the following signal will subtract from the primary signal.
2 => g.op; // for substract
Code:
s1 => g;
s2 => g;
s3 => g;
0.1 => s1.next;
0.2 => s2.next;
0.4 => s3.next;
<<< g.last() >>>;
s1 =< g; // disconnect s1 from g, and see what g will output
<<< g.last() >>>;
result:
-0.500000 :(float)
-0.200000 :(float)
the first comes from the last value of s1 - s2 - s3
= 0.1 - 0.2 - 0.4 = -0.5
the second, after unchucking s1 from g,
the s2 become the primary signal instead, thus ... g outputs s2 - s3
= 0.2 - 0.4 = -0.2
now, i'll try op = 3
this is gonna be easy.
Code:
3 => g.op; // for multiplication
s1 => g;
s2 => g;
s3 => g;
3.0 => s1.next;
2.0 => s2.next;
5.0 => s3.next;
<<< g.last() >>>;
result: 30.000000 :(float)
(equals 3.0 * 2.0 * 5.0, plainly)
but the division behaves just like subtraction
only it's dividing.
Code:
4 => g.op; // for division
s1 => g;
s2 => g;
s3 => g;
3.0 => s1.next;
2.0 => s2.next;
5.0 => s3.next;
<<< g.last() >>>;
<<< g.last() >>>;
result:
0.300000 :(float)
0.400000 :(float)
the first equals 3.0 / 2.0 / 5.0 = 0.3
and second 2.0 / 5.0 = 0.4, for real!
chuckles
PostPosted: Fri Jul 06, 2007 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
kijjaz: thanks for the detailed explanation of the way .ops work. I thought it might have something to do with multiple chucks but I wasn't clear on it.
The crucial thing is that all these computations are done on individual samples. I was trying to see if I could figure out a way to do it without having to process each single sample in buf1. Because you could certainly do it that way.
...r...
PostPosted: Sat Jul 07, 2007 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, Ugens are usually MUCH cheaper then manual code in ChucK, at least in situations where they are suitable. "Gain" is realy simple and "OnePole" is a bit more involved but still only a few multiplications.
Another issue is that processing every Nth sample for a envelope follower would lead to problems. Say you'd poll it ever 10 ms, that would mean that from the perspective of the envelope follower a 100 Hz sine would look like pure dc-offset at a value dependant on how the wave syncs relative to your code... Clearly that would be undesireable. The results on musical material might be interesting but they wouldn't be a envelope follower per-se.
