today> Sorry, no program tonight. Chez Mosc
Micro Modular Synced (?) to Engine?
Page 1 of 1 [5 Posts]
G2DREAM
PostPosted: Sun Jul 29, 2007 5:34 am    Post subject: Micro Modular Synced (?) to Engine?
Subject description: Am i doing anything wrong?
Hi to everybody!
Here is the scenario:My Micro sends its sound to my engine.
My engine sends clock to Micro but these two doesn't quite seem to sync perfectly. The difference is audible, that is what i can hear after i connected the drum oscs and tried to stuck two drum sounds to test the setup?
Any ideas?
_____________
cyber-evolution
 Filesize:  69.78 KB
 Viewed:  4789 Time(s)
 Filesize:  72.61 KB
 Viewed:  4785 Time(s)
gomidas
G2 patch files: 6
PostPosted: Mon Jul 30, 2007 1:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi G2Dream!
Did you try with the loop function OFF on the Micro?
Are you monitoring MIDI thru a DAW sequencer or is it (the G2 engine) directly connected to the Micro?
Also I do use an external Midi device (RED Micro Sync) with a tap tempo to sync multiple G2 and Nord on the fly....
Hope it help Cool
PS:The micro sync is discontinued product, now there is a new version.. http://www.redsound.com/products/soundbitemicro
G2DREAM
PostPosted: Mon Jul 30, 2007 7:23 am    Post subject: Reply with quote  Mark this post and the followings unread
gomidas wrote:
Hi G2Dream!
Thanks for your reply!
I tried it with the loop on and off but it had no result. The G2 sends directly its clock to the Micro.
Here is an example of the sonic result.
In this example i press multiple times the RUN button like Start/Stop but some times is on sync but other times...
Sound 1.mp3
 Filename:  Sound 1.mp3
 Filesize:  249.39 KB
 Downloaded:  1020 Time(s)
Fozzie
G2 patch files: 49
PostPosted: Mon Jul 30, 2007 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I can't listen to your file right now so at the risk of typing complete nonsene: could it be that you need to use the "active" output from your midiglobal module (you probably can't connect it directly but need to patch a temporary high upon clock restart), to make sure that the micro sequencer always starts on the first beat after stopping/starting the clock?
sheridan
Audio files: 27
PostPosted: Thu Aug 02, 2007 5:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi mate,
I don't know anything about the original NM, but looking at your pictures, I'm guessing you need to patch the Active socket to the Reset socket to reset the squencer (NM) to the incoming clock, rather than just starting the internal clock... just a guess though.
transformer Sheridan
Hear music and Nord Modular G2 patches and find out music production tips at
http://www.nitetimeproductions.co.uk
