NL2X demo, saving a layered configuration, etc
Page 1 of 1 [4 Posts]
fischek
PostPosted: Mon Aug 27, 2007 1:05 am    Post subject: NL2X demo, saving a layered configuration, etc
Subject description: Just a couple of questions
As I am still new to VA synthesis, I am not so good at recreating sounds. That is why I was wondering if anyone knew which preset is used (if a preset at all) for creating the strings part of the: demo 3 song
http://www.clavia.se/MP3s/MP3%20files/NL2Xdemo3.mp3
Also, I am beginning to play with layering the sounds and modifying those single sounds within the layered config - can that be called a performance then? A couple of sounds at the same time = performance, right?
My question is, is it possible to save such configuration just like any other performance? (the first 100 locations, etc).
Aleksandar
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Aug 27, 2007 2:49 am    Post subject: Re: NL2X demo, saving a layered configuration, etc
fischek wrote:
As I am still new to VA synthesis, I am not so good at recreating sounds. That is why I was wondering if anyone knew which preset is used (if a preset at all) for creating the strings part of the: demo 3 song http://www.clavia.se/MP3s/MP3%20files/NL2Xdemo3.mp3
I think even Calavia doesn't know anymore...{qoute]Also, I am beginning to play with layering the sounds and modifying those single sounds within the layered config - can that be called a performance then? A couple of sounds at the same time = performance, right?[/quote]Yes
Also yes.
Wout
fischek
PostPosted: Mon Aug 27, 2007 3:09 am    Post subject: Reply with quote  Mark this post and the followings unread
But those first 100 locations are occupied right? So I would be overwritting something already there. I guess there is a possibility to return everything to factory default afterwards. I was also wondering if I could use the Nord Generator to save the performance?
Thanks Wout - you're always fast to reply and give a meaningful and useful info.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Aug 27, 2007 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't work with the NL2X. NordGen doesn't do Performances, but SendSX is a good substitute, although one can't see the parameter settings, but it works for up and downloads.
http://www.bome.com/midi/sendsx/
Wout
