Schulte Compact A Phasing
Page 10 of 27 [660 Posts]
Goto page: Previous 1, 2, 3, ..., 8, 9, 10, 11, 12, ..., 25, 26, 27 Next
b-funk
PostPosted: Thu Feb 14, 2008 3:09 am    Post subject: Reply with quote  Mark this post and the followings unread
i found a relay that works. and it´s quite cheap.
for those who encounter similar problems, here it is:
http://banzaieffects.com/Finder-Relay-30.22-12V-pr-16251.html
best wishes,
tobias.
b-funk
PostPosted: Thu Feb 14, 2008 3:17 am    Post subject: Reply with quote  Mark this post and the followings unread
by the way: i found a inconsistency in the bom:
there you list 2 1k trimpots, but following the sikscreen on the board, 1 1k and 1 10k is needed.
best wishes,
tobias
jhaible
PostPosted: Thu Feb 14, 2008 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
best wishes,
tobias.
That's the same I used on my 2nd prototype. Works here, as well. Smile
Actually, I intended to use a Finder relay right from the beginning.
But I bought one that was too small to fit into the DIL footprint, and when I checked what I had in teh drawer, I found the Meder, which then went into the BOM as an example.
I'll write a new BOM soon, and I'll also fix the trimpot typo.
JH.
jhaible
PostPosted: Thu Feb 14, 2008 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Updated BOM is up:
http://www.jhaible.heim.at/compact_clone/jh_krautrock_phaser_bom.pdf
JH.
morbank
PostPosted: Thu Feb 14, 2008 4:02 pm    Post subject: Transformer mA? Reply with quote  Mark this post and the followings unread
Can someone here tell me what the mA should be for the transformer?
Thanks, Clay
And thanks for the banzaieffects.com link Tobias!
etaoin
PostPosted: Fri Feb 15, 2008 12:32 am    Post subject: Re: Transformer mA? Reply with quote  Mark this post and the followings unread
As there are 200mA fuses right after the transformer, I'd say 2 x 200mA or higher...
http://www.casia.org/modular/
morbank
PostPosted: Fri Feb 15, 2008 11:57 am    Post subject: Transformer mA? Reply with quote  Mark this post and the followings unread
Sorry everyone for all the newb questions. This phaser is the most sophisticated thing I've built and some of the workings are new to me.
I'm a little confused about how the transformer works, I read that Jurgen has moved it off of the pcb for safety reasons but I'm unclear if this means I should use an external power supply? Like this one?
Thanks again for all the help so far!
-Clay
http://www.banzaieffects.com/EH-18V-DC-US-500mA-pr-13572.html
b-funk
PostPosted: Fri Feb 15, 2008 2:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
well, the powersupply you linked to is a dc supply, you want ac. or you use the motm-style connection on the board (/-15v dc) but then you have to omit the rectification circuit on the board.
best wishes,
tobias.
morbank
PostPosted: Fri Feb 15, 2008 2:52 pm    Post subject: Transformer mA? Reply with quote  Mark this post and the followings unread
Oops, I meant AC, thanks Tobias.
Why are there 5 pins for connecting to power if the ac adapter only has + & -?
-Clay
jhaible
PostPosted: Fri Feb 15, 2008 3:24 pm    Post subject: Re: Transformer mA? Reply with quote  Mark this post and the followings unread
-Clay
This connector is for *AC*, not DC.
You need two secondary windings of 16 ... 18V - which requires 4 pins on the connector. The connectors I'm using come in 2Pin, 3Pin, 5Pin, 8Pin, 10Pin.
So 5Pin was the obvious choice.
You can also use a center tapped 32 ... 36V winding - that's like two separate windings of half the voltage connected at the center tap point.
in fact, the 5-pin connector has pins 2 and 4 connected on the board - which makes a center-tapped winding from two separate windings.
Now, there is als the possibility to just use a *single* 16 ... 18V winding, or a 16 ... 18v AC (AC !) Wallwart, and just connect it to pins 1 and 2 of the 5Pin connector. Then the whole Phaser will run on half wave rectifiers instead of full wave rectifiers. Allthough I've tested my prototype wih this method, it's recommended to increase the capacitance of the two 470uF reservoir caps to something bigger. 1000uF / 40V or even 2200uF / 40V would be a good start. There should be enough space on the board for these. With the 470uF and half wave rectification (18V AC Wallwart) I got it working "just so" - with some component tolerances it might "just so" _not_ be working.
But yes, even though I recommend proper full wave rectification with a transformer with two secodary windings, AC-Wallwart supply is certainly possible if you keep the above in mind.
JH.
morbank
PostPosted: Fri Feb 15, 2008 4:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the breakdown Jurgen! Let me make sure I understand.
I need an 120v compatible, AC transformer, with 2 secondary windings both at 16-18v each?
If I were looking for this online how might it be listed?
And lastly, where should the ac plug be attached?
Anyone have pictures of there transformer?
-Clay
[/quote]
ziwzih
PostPosted: Fri Feb 15, 2008 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure which is cooler: the fact that my boards arrived today or Jürgen's Gentle Giant return address sticker! Very Happy
This is my first post here but I expect to be posting a ton of annoying newbie questions shortly.
Audio files: 328
PostPosted: Fri Feb 15, 2008 5:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
ziwzih wrote:
[...]but I expect to be posting a ton of annoying newbie questions shortly.
So do we Laughing
welcome Exclamation
jhaible
PostPosted: Sat Feb 16, 2008 3:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you sure you want to build the mains stuff yourself?
I'd gladly help, but that kind of stuff is hard to convey over the internet.
You really should have somone standing next to you who is experienced with mains connections, when you do it for the first time.
There's so much to think about: Primary fuse, two independent means of fixing the wires mechanically, length of protective earth wire compared to the other wires, means of connecting protective earth to the metal enclosure .. and probably 10 other things I don't remember but do them "automatically".
Maybe it's a better solution to just go for a 18V AC wallwart and two 1000uF / 40V capacitors instead of the two 470uF ones.
JH.
jhaible
PostPosted: Sat Feb 16, 2008 3:29 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm still hunting for a mint "Free Hand" and "In A Glass House" Vinyl.
If anyone has one of these to sell in really pristine condition, please let me know!
JH.
whomper
PostPosted: Sat Feb 16, 2008 6:54 am    Post subject: To 'C' or not to 'C' Reply with quote  Mark this post and the followings unread
I have probably purchased the non 'c' of the BC550, BC560 and BD239.
Is it a good substitute or should I purchase the 'C' version of the above 3.
Thanks,
Whomper
morbank
PostPosted: Sat Feb 16, 2008 9:51 am    Post subject: Transformer mA? Reply with quote  Mark this post and the followings unread
You're right Jurgen, I should have someone helping me. I wish I knew someone who could! I guess I thought I could duplicate the transformer design from someone else on this list... Well, what are the downsides of using the wallwart? It might just be the way to go. Thanks again for all the help.
-Clay
jhaible
PostPosted: Sat Feb 16, 2008 12:02 pm    Post subject: Re: To 'C' or not to 'C' Reply with quote  Mark this post and the followings unread
Thanks,
Whomper
The BC550 and BC560 are probably good enough without C grading.
(But I haven't tested.)
The BD239 should really be the C type, as the beta is very, very low otherwise.
You could try other npn transitors in TO-220 package with B-C-E pinout, rated for 40V or above, 500mA or above, and beta > 80.
JH.
jhaible
PostPosted: Sat Feb 16, 2008 12:07 pm    Post subject: Re: Transformer mA? Reply with quote  Mark this post and the followings unread
-Clay
Half wave rectifying is considered "not elegant", because it needs overly sized capacitors, and creates higher peak currents. But the more I think of it, the more attractive it is to simply use a single wall wart and just upsize the capacitors. We're talking of just a few cents more on caps here (and there's plenty space on the board) - at the benefit of a safe and easy way too hook it all up at the mains.
JH.
morbank
PostPosted: Sat Feb 16, 2008 2:56 pm    Post subject: transformer mA? Reply with quote  Mark this post and the followings unread
Well I'm happy to be the guineapig! It would definatly simplify the build for me.
Are the 470uF reservoir caps the only components I would need to swap out?
-Clay
jhaible
PostPosted: Sat Feb 16, 2008 4:49 pm    Post subject: Re: transformer mA? Reply with quote  Mark this post and the followings unread
-Clay
Actually I've played guinea pig myself - lazy that I am, I made most of the tests with just the same (barely) 18V AC wallwart plugged into the Krautrock Phaser that I had used for the Tau and the Triple Chorus. Smile
It even worked with 470uF caps in place - but go for larger caps to have some reserve for component tolerances, mains voltage drops, etc.
Yes, it's just the two capacitors, no other components.
JH.
jhaible
PostPosted: Sat Feb 16, 2008 6:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
For all who have missed the PCB + LDRs order deadline:
I still have quite a number of boards, and LDRs are available from here:
https://www.distrelec.com/ishop/StaticHTML/shared/distrelec/
Search for "M996011a" (without the quotation marks)
JH.
morbank
PostPosted: Sat Feb 16, 2008 7:05 pm    Post subject: Transformer mA? Reply with quote  Mark this post and the followings unread
Sounds good to me! I'm still waiting on a few parts to show up and then I'll give it a go.
-Clay
Oh, one more question. Can the voltage for the 100nF and 220nF capacitors be as high as 250v?
http://www.banzaieffects.com/product.php?productid=23592
http://www.banzaieffects.com/product.php?productid=24367
jhaible
PostPosted: Sat Feb 16, 2008 7:24 pm    Post subject: Re: Transformer mA? Reply with quote  Mark this post and the followings unread
-Clay
Sure ... as long as they fit into the board!
JH.
whomper
PostPosted: Sun Feb 17, 2008 12:15 pm    Post subject: Re: To 'C' or not to 'C' Reply with quote  Mark this post and the followings unread
Thanks,
Whomper
JH.
Well, went in to the store today and found a replacement:
BD239C -> BD241C
BC560C -> BC557C
Are they ok?
Also, has anyone tested the relay Gruner 213D?
Whomper
