How to re-create this bass synth?
Page 1 of 1 [6 Posts]
The_Funk_Out
PostPosted: Sun Oct 21, 2007 5:13 pm    Post subject: How to re-create this bass synth?
Subject description: Help
Hey all i have a snippet of the track "Bodyrox - Yeah Yeah (Feat Luciana)". In the snippet you`ll hear a very cute bass riff tho its not the riff im concentrating on, its the sound used, id like to know how to re-crate the sound used!
Id be eternally grateful if someone could tell me or give me a patch/preset. I realise a patch/preset wouldnt be much of a learning experience but im not fussy.
Thanks a bunch!
Tommy
Bodyrox - Yeah Yeah (Feat Luciana) SAMPLE.mp3
 Filename:  Bodyrox - Yeah Yeah (Feat Luciana) SAMPLE.mp3
 Filesize:  60.33 KB
 Downloaded:  632 Time(s)
EdisonRex
Audio files: 172
PostPosted: Mon Oct 22, 2007 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
what synthesizer are you trying to mimic this patch for?
Garret: It's so retro.
The_Funk_Out
PostPosted: Mon Oct 22, 2007 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
z3ta+ pal
Thanks
Tommy
CHECK ME OUT ON MYSPACE!!!
www.myspace.com/thefunkout
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Oct 22, 2007 9:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds to me like the bass part is being doubled by another patch. The bass itself is fairly conventional dual osc bass synth sound.
The second patch sounds like a phase sync patch with minimal or no sweep, played an octave above.
ekli
PostPosted: Mon May 05, 2008 2:28 am    Post subject: bodyrox Reply with quote  Mark this post and the followings unread
try nexus and the Bass expansion, http://refx.com/?lang=en&page=products/nexus/expansions you will find in the xpbass the bodyrox preset bass included, it's just called bodyrox
EdisonRex
Audio files: 172
PostPosted: Thu May 08, 2008 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's a sawtooth and a square wave mixed, I'm pretty sure, and filtered down with some resonance. It's actually a pretty common configuration for bass, and I won't go into why, but saw and square, and saw and tri, are nice bass starters. I agree I think there's an octave in there, probably the square.
To get closer to the sound, both the envelope for the filter, and the filter itself, need to be thought out. I'm guessing some sort of 12dB filter, but it'd be punchier with a 24dB. You'd need to play with two EGs to get it to work right, but any synthesizer with a couple of Os has a couple of EGs.
