 Forum index » Clavia Nord Modular » G2 Patches - Completed » Piano
FM Electric Piano
Page 1 of 1 [7 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri May 14, 2004 4:30 pm    Post subject: FM Electric Piano Reply with quote  Mark this post and the followings unread
Here is a DX7 style FM electric piano patch. It is taken almost exactly from one of the DX7 factory ROM sounds. I think it sounds better (cleaner, with more dynamics) than the original. I haven't done much work translating FM patches because of the impending(?) dx operator modules.
Although FM is no longer the king of realistic, acoustic synthesis, it is capable of a wealth of great sounds (cliché's excepted). It's great to have the technology available and not constrained to that horrible DX7 UI.
EPiano.pch2
DX7 EPiano Patch
 Filename:  EPiano.pch2
 Filesize:  2.2 KB
 Downloaded:  2508 Time(s)
Fozzie
G2 patch files: 49
PostPosted: Wed Aug 11, 2004 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great piano! I have a problem with it, though. I hear inconsistent keyclicks over my headphones (also when I plug into my engine directly) when I play this patch. Is it me, my engine or does this patch just do it (it is not *very* loud but clearly audible.
Audio files: 297
PostPosted: Wed Aug 11, 2004 1:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
The variation in the clicks is caused by the oscillators running at a random phase with respect to the envelope start, so the sound may kick in at various momentary oscillator output signals.
There are two things you can try to do about it :
- Set the attacks a bit slower
- Sync all oscillators to the gate signal
Jan.
Audio files: 225
PostPosted: Wed Aug 11, 2004 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also the mixer that drives the output module in the poly section seems to overload, so turning down the levels on the inputs a bit will make it sound a little cleaner.
Audio files: 297
PostPosted: Wed Aug 11, 2004 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
tip from Rob Hordijk :
In the FX section set fx or bus input to -6dB and the output to +6dB to give a little extra headroom for FX processing.
Jan.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Aug 11, 2004 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Howard & Jan
I should repost some of my old old stuff with little glitches Embarassed
Of the 2 'click busting' techniques mentioned, sync to keyboard gate works most effectively but costs some more DSP (connecting anything to the sync input bumps up that oscillator's load).
Audio files: 225
PostPosted: Wed Aug 11, 2004 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
The clicks add something raw and edgey to the sound. I don' think there is anything wrong with this patch. I think Fozzie was just trying to understand it.
