<on air> Modulator ESP Adventures In Sound
 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
assigned knobs dont turn correct in nomad
Page 1 of 1 [3 Posts]
nathan
PostPosted: Sat Mar 15, 2008 6:25 am    Post subject: assigned knobs dont turn correct in nomad Reply with quote  Mark this post and the followings unread
when i assign parameters to knobs and i turn the knobs, i thought there was a weird mistake in the new nomad that you just dont see them visually turn
(i am not talking "morphgroups")
but now i noticed that the entire parameter doesnt change correctly.
it's really weird, the knob jams or something, sometimes it turns only 10 degrees when you turn it 360. and sometimes it goes further then that. (rarely the entire 360)
in clavia's editor this all works fine.
anyone else has this?
chresan
PostPosted: Sat Mar 15, 2008 10:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi nathan,
does the 'jamming' happen only on specific modules / parameters ?
Could you post me a patch where this problem occurs.
Christian
http://nmedit.sf.net
julien
PostPosted: Tue Mar 18, 2008 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Christian,
I think this is related to the "hook mode" (we talked about it once). This happens when the editor gets unsynchronized with the synth.
Nathan: do you have the nord setup to hook mode ? Try to put it to immediate mode, it should solve the problem.
