 Forum index » Clavia Nord Modular » G2 Performances - Experimental
rythmn strummer
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sat Jun 19, 2004 6:03 am    Post subject: rythmn strummer Reply with quote  Mark this post and the followings unread
I know lots have people have contributed very good strummer patches on the list. Here is my late contribution anyway.
The strummer is in slot B and responds to monophonic key presses, you can also press another key (above) which shifts two of the strings up.
The up down strum voltage is provided by a pair of glide modules, setting then to slightly different rates allows for humanising the strumming*.
The level sequencer provides accent and the gate output switches between glide1 & 2*. The event sequencer provides strum start (row one) and damping (row two).
strummer.prf2
rythmn strummer
 Filename:  strummer.prf2
 Filesize:  6.68 KB
 Downloaded:  1956 Time(s)
