sync circuit / tap tempo
Page 1 of 1 [2 Posts]
Clack
PostPosted: Mon Mar 24, 2008 2:15 am    Post subject: sync circuit / tap tempo Reply with quote  Mark this post and the followings unread
Hi I have been experimenting with a VCclock that changes its timing through an CV sequencer - that means you can choose the length of a note as well as the pitch in a sequence.
I really want to then count intervals from the sequence and then add regular 4/4 divisions to it. this would be done by a counter then divider
I have realised that time division is impossible with logic ( or is it? )
would it be feesable with microcontrollers in a sort of tap tempo way? being it would take a few cycles before it syncs?
has anyone already made a sort of tap tempo circuit, how easy are they to design? ( im at the very beggining of PIC micros )
 Filesize:  4.54 KB
 Viewed:  463 Time(s)
Clacktronics.co.uk
igor_d
PostPosted: Tue Mar 25, 2008 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Variant: if clock osc a saw, (from 0 up to V, for example), it is possible to define Vref's = 3/4V, V/2, V/4 for comparators.
Their outputs - sync pulses.
