frijitz
Audio files: 54
 Posted: Thu Jan 15, 2009 8:33 pm    Post subject:
 Subject description: The bus has just rolled in! |
Good news ... The DoubleDeka is now for sale at bridechamber.com!
Ian |
drapdap
 Posted: Fri Jan 16, 2009 5:29 am    Post subject:
http://www.bridechamber.com/bridechamber.com/F%20DoubleDeka.html
Not cheap, but f+++! A dream came true, a hardware wavedraw osc.
Congratulations on that Ian, you are massive!
I wanted to ask about the sliders, - it might have been mentioned earlier-
but how many kiloOhm sliders are we talking about?
róbert |
frijitz
Audio files: 54
 Posted: Fri Jan 16, 2009 10:19 am    Post subject:
 	  | drapdap wrote: | 	 		  | I wanted to ask about the sliders, - it might have been mentioned earlier-but how many kiloOhm sliders are we talking about  |
Not critical, since they are used as voltage dividers.  Nominally 10k.  Anything 2k - 50k should be fine.
Ian |
pristak
  Joined: Nov 17, 2006 Posts: 37 Location: Dallas, Texas
 Posted: Fri May 08, 2009 7:04 am    Post subject:
Well, my full kit is finally in the mail.  I've been intending to order this for a while.
Is anyone else working on this one?  I think this will jump ahead on my list since most of my other projects are waiting on backordered parts. |
pristak
pristak
 Posted: Thu May 28, 2009 7:50 pm    Post subject:
| I had some more progress on this.  The pic's are up on the muffwiggler site. |
pristak
 Posted: Sun May 31, 2009 7:48 pm    Post subject:
Finished.  It worked fine first try.  I still need to calibrate it and reverse the wiring on the Sync switch, but everything worked first try.
dave_3283
 Posted: Mon Jun 01, 2009 6:29 am    Post subject:
| Does anyone know the size on the linear pot PCB?  I've been doing 4u Serge-ish panels and would like to figure out if I can make this project fit... |
frijitz
Audio files: 54
 Posted: Mon Jun 01, 2009 8:27 am    Post subject:
 	  | pristak wrote: | 	 		  | Finished.  It worked fine first try.  |
   Glad to hear it! Any chance for some mp3's?
Ian |
frijitz
Audio files: 54
 Posted: Mon Jun 01, 2009 8:29 am    Post subject:
 	  | dave_3283 wrote: | 	 		  | Does anyone know the size on the linear pot PCB?  |
I do.
4"x6.6"
Ian |
Coriolis
  Joined: Apr 11, 2005 Posts: 616 Location: Stilling, Denmark
 Posted: Mon Jun 01, 2009 2:26 pm    Post subject:
Pristak, that is downright nice! Sigh..I'll never get that to fit in my panel format...
C _________________ Some Rubber Stamp Sound Effects - and other sound effects |
pristak
 Posted: Mon Jun 01, 2009 3:58 pm    Post subject:
I won't likely have a chance to get serious mp3's together for a while.  I am reorganizing my studio and don't have all the power cabling and placement worked out.  I get married very soon as well so time is limited right now.
I may be able to put up a quick demo sometime soon, but I've done that before and been real disappointed when I listened back later.  We'll see. |
frijitz
Audio files: 54
pristak
 Posted: Sat Jun 06, 2009 9:31 pm    Post subject:
It's calibrated to the best of my abilities with what I have available.  Ie, it stays in tune according to my guitar tuner across the octaves.
Samples are up on the muffwiggler site.
http://www.muffwiggler.com/forum/post-71331.html#71331 |
lexvortex
 Posted: Sun Jun 07, 2009 2:03 am    Post subject:
Problem with DDeka |
Hi Ian,
  I just finished building two of these    They sound awesome!! I am however having a slight problem with the second one I built, it tracks well in the lower frequencies up to the mid-high frequencies but after it hits C7 or 8 (I'm not sure if it's that high) it will start to go down in pitch for about four notes then goes silent past that,  my other one goes to this pitch easily.  I don't know if it makes a difference but I accidentally put one 1N914 rather than an 1N4148 for one of the diodes on the slider board but I figured it didn't matter too much.  Any help would be appreciated.
Also how do I wire up the HF out?
Thanks,
Dave |
frijitz
Audio files: 54
 Posted: Sun Jun 07, 2009 7:41 am    Post subject:
I get a 404 on that and I couldn't figure out where to look for the samples.  Which subforum?
Glad you got the tracking OK.
Ian |
pristak
 Posted: Sun Jun 07, 2009 8:11 am    Post subject:
Ian:
Its in the same thread I started earlier.  It is in the DIY subforum.  They changed the layout and the DIY section is near the bottom now.  I liked it better when it was near the top.
lexvortex:  The HF out is wired directly from the pole of one of the 6 position switches. |
pristak
 Posted: Sun Jun 07, 2009 8:28 am    Post subject:
Ok, lets try this
Doubledeka w/cgs tube vca. Sequenced by Doepfer maq 16/3. Recorded straight into Cubase using a Presonus Firestudio. A little compression (UA Fairchild) and eq (UA Neve 1073) as put on in the mix. |
pristak
 Posted: Sun Jun 07, 2009 8:33 am    Post subject:
I like this one better.  Where did my fade out go in the last one?  heh...
Doubledeka VCO, Into LPG Sequenced by Doepfer MAQ 16/3. About 1 minute in, exponential FM is provided by a Jerkster chaos. Recorded straigt into Cubase using a Presonus Firestudio, no fancy effects. |
frijitz
Audio files: 54
 Posted: Sun Jun 07, 2009 8:34 am    Post subject:
Re: Problem with DDeka |
 	  | lexvortex wrote: | 	 		  | I am however having a slight problem with the second one I built, it tracks well in the lower frequencies up to the mid-high frequencies but after it hits C7 or 8 (I'm not sure if it's that high) it will start to go down in pitch for about four notes then goes silent past that,  my other one goes to this pitch easily. |
Well, it does usually go down a bit as it approaches the very end of its range.  But it shouldn't be happening so low.  The diode substitution doesn't matter a bit.
Not sure what to look for.  Solder bridges?  Correct integrator cap?
 	  | Quote: | 	 		  | Also how do I wire up the HF out? |
First you have to have something to hook it up to.  It's an aux signal for possible uses in other waveshapers, etc.
Ian |
frijitz
Audio files: 54
 Posted: Sun Jun 07, 2009 8:44 am    Post subject:
 	  | pristak wrote: | 	 		  | Doubledeka VCO, Into LPG Sequenced by Doepfer MAQ 16/3. About 1 minute in, exponential FM is provided by a Jerkster chaos. Recorded straigt into Cubase using a Presonus Firestudio, no fancy effects. |
Thanks, I like them.  Both fat and buzzy.
Ian |
frijitz
Audio files: 54
 Posted: Sun Jun 07, 2009 8:48 am    Post subject:
 	  | frijitz wrote: | 	 		   	  | lexvortex wrote: |
First you have to have something to hook it up to.  It's an aux signal for possible uses in other waveshapers, etc.   |
Oh, you meant where on the circuit?  At the highest position of the octave switch. Point "b" on the schematic.
Ian |
lexvortex
 Posted: Sun Jun 07, 2009 1:02 pm    Post subject:
Hi Ian,
  Thanks for the responses    I figured out what was wrong... just 4am retardation    I had the octave switch up too high in comparison to my tuning source and got them all confused. Got it all sorted out today and both are working great!!
Dave |
sduck
 Posted: Mon Jul 06, 2009 10:47 am    Post subject:
| I'm just about done with the wiring on this, and wanted to ask about something that's been vexing me. On the pcb there is a hole marked v/o on the side next to R7. There's also a hole marked v/o over in J2, which is connected to R6. These both feed into the same place through identical resistors, so I'm wondering - why? Am I missing something? |
frijitz
Audio files: 54
 Posted: Mon Jul 06, 2009 12:17 pm    Post subject:
 	  | sduck wrote: | 	 		  | I'm just about done with the wiring on this, and wanted to ask about something that's been vexing me. On the pcb there is a hole marked v/o on the side next to R7. There's also a hole marked v/o over in J2, which is connected to R6. These both feed into the same place through identical resistors, so I'm wondering - why?  |
Good spot.  It's just an extra input, in case anyone needs it.  So just ignore it if you don't need it.
Ian |
