Making of a drum synth
Page 1 of 1 [6 Posts]
Joel
PostPosted: Wed Sep 03, 2008 7:59 am    Post subject: Making of a drum synth Reply with quote  Mark this post and the followings unread
Hi all,
a guy called Philipp has started a new blog, Making of a drum synth, detailing his construction of a tr-808-style drum computer. Analog sounds, digital control!
Only a few posts so far and no confirmed schematics (a couple of unconfirmed ones) but seems to be coming along quite quickly, definitely one to watch....
Joel
Luka
PostPosted: Tue Sep 09, 2008 1:34 am    Post subject: Reply with quote  Mark this post and the followings unread
if your keen on this also check out the mb808 project joel, run 3 is about to happen and it looks like doug is even sorting out entire kits ala xoxbox.
this really is a hot project. im about to order the parts for mine this week.
http://www.eight-oh-eight.org/phpbb2/forums.html
problemchild
melbourne australia
Joel
PostPosted: Tue Sep 09, 2008 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for that Luka, looks great! Do you have a guetsimate for how much the project will cost in total?
Luka
PostPosted: Tue Sep 09, 2008 7:22 am    Post subject: Reply with quote  Mark this post and the followings unread
id say somewhere around 5-600 for a pimped out mb808
however doug is yet to cost out the full kit
keep an eye on the forum
but that is so worth it for what you get
mbSEQ + original 808 drum voices, match made in heaven
im going to implement the same SEQ design for my SDS3s and THMPS drums
problemchild
melbourne australia
creatorlars
PostPosted: Wed Sep 10, 2008 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Luka -- I'm planning something similar in a modular format. I want a rackmount MB808 sequencer + trigger distributor + mixer in a case with a bunch of drum module clones. At first I wanted to avoid patching triggers/audio outs, but I think if everything is in a single enclosure then it's going to work well and allow a lot of flexibility as far as FX modules and drum-voice stacking goes (esp. with banana cables... just patch the same trigger out to my 808 kick and an SDS3 voice, for example.)
bugfight
PostPosted: Wed Sep 10, 2008 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
mmmmmm me likey
