Bare SAW VCO interest?
Page 4 of 4 [81 Posts]
Sell a simple, cost-effective, stable, accurate VCO?
Where have you been all my life -- this is exactly what I have been waiting for!
77%
 77%  [ 21 ]
No, I have too many VCOs already.
0%
 0%  [ 0 ]
No, I only like VCOs that drift and don't track over more than 3 octaves.
3%
 3%  [ 1 ]
No, your external waveshapers are too weird.
7%
 7%  [ 2 ]
No, we don't use VCOs around here.
7%
 7%  [ 2 ]
What's a VCO, and why would I want one?
3%
 3%  [ 1 ]
Total Votes : 27
Starspawn
PostPosted: Sat Jun 18, 2016 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I made a striboard of this Smile
To mate with a 5pulser ...
EDIT for revised layout.
Moosgummi
PostPosted: Mon Jun 20, 2016 6:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice! Thanks for posting this. Time for a stripboard IF synth now...
frijitz
Audio files: 54
PostPosted: Mon Jun 20, 2016 6:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the interest. It's good to see folks using good ole stripboard.
Ian
https://www.youtube.com/channel/UC8mKuBoR8bfHTLYRJ1sl0RA
http://ijfritz.byethost4.com
Starspawn
PostPosted: Thu Aug 25, 2016 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hows this for interest? Smile This is the plan I mentioned.
Posted Image, might have been reduced in size. Click Image to view fullscreen.[/img]
Moosgummi
PostPosted: Tue Aug 30, 2016 2:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ooooh, I like this!
Starspawn
PostPosted: Thu Dec 29, 2016 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well under way with these things now. But coming back to the saw core together with the other things I realize its level is to low. Just 1V P2P.
Is that correct for the schematic?
Theres no change from -input to the out, and it looks like it should be 5x gain except for the parts going to ground?
Ive had some trouble with LF351 before ...
As you see in the stripboard ive connected balance to the -input, dont rememer why, but without it I dont get sound, the other balance pin doesnt seem to matter.
And is the schematic correct in less than 2pf value for the lf351 cap??
I also took out the reference voltage and used the layout from the teezer instead, which was more stable.
And ooops, if you read this Ian look at the 2Q/4Qs on the panels ... someohow I imagined a bias CV input, but theres no such thing Very Happy
Could there be though?
EDIT: Never mind, tayda LF351, enough said. Changed for 071, lifted balance pin, all OK.
