Recommended PCB manufacturers
Page 1 of 1 [5 Posts]
amos_joseph
PostPosted: Thu Sep 11, 2008 8:20 am    Post subject: Recommended PCB manufacturers Reply with quote  Mark this post and the followings unread
I'm getting ready to do my first run of circuit boards. I've been using BatchPCB.com for prototyping, but I'm not sure who I should use when I'm ready to make a larger run. I'm planning on doing an initial run of 50 - 100 boards, depending on price.
I know there are several people on the forum that regularly produce small runs. Who do you use? Anyone I should avoid?
bugbrand
PostPosted: Thu Sep 11, 2008 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I was using Futurlec - but they're not *so* great - they don't really do much bulk discount (they initially claimed they did, but a couple of orders down the line they pretty much turned around on that hohum) and their system is a little chaotic at times.
I've been using PCBcart.com recently and initial findings seem very positive. The system is pretty well done (easy to spec things and re-order), prices seem excellent even for small runs (even under 20units ain't bad) and the communications I've had have been great - they're always quick and friendly at answering questions.
Hope to have some nice pics to show next week......
http://www.bugbrand.co.uk
amos_joseph
PostPosted: Thu Sep 11, 2008 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow, PCBcart looks pretty good, price-wise. My quote was $150 for a batch of 100. The same quote at Futurlec was over $400. Shocked
bugfight
PostPosted: Thu Sep 11, 2008 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
i've used goldphoenixpcb (which iirc, is where patchpcb boards are made)
with good results. they have a nice price for 1000 cm sq
i've heard good things about pcbcart, and will try them on my next pcb...
both are chinese fabs
bubblechamber
PostPosted: Thu Sep 11, 2008 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
i've been using Myropcb, myropcb.com, for a long time. they're really good, slightly cheaper than PCBcart, and are based in Canada so it's easy to get someone on the phone if you have a question. their boards are some of the best made i've come across. i've desoldered and resoldered the same pad 3 or 4 times without the pad coming off, any color soldermask you want and they are really fast in turnaround.
david
You can check your anatomy all you want, and even though there may be normal variation, when it comes right down to it, this far inside the head it all looks the same.
