3rd run of PCBs for the PS3100 Resonators & the X-panfader
Page 9 of 14 [349 Posts]
Goto page: Previous 1, 2, 3, ..., 7, 8, 9, 10, 11, 12, 13, 14 Next
PostPosted: Wed Apr 22, 2009 3:58 am    Post subject: Reply with quote  Mark this post and the followings unread
goikem wrote:
hi fonik- i searched your website and here for a fpd file for the faceplate (i really like it), and haven't found it. are you sharing?
thanks, matthew
done.
http://www.modular.fonik.de/Page46.html
Rvlt
PostPosted: Thu May 07, 2009 5:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi everyone,
I found an error in the X-Pan BOM: Resistors 41, 42, 43 and 44 must be 100k and NOT 47k (schematic is right, but BOM says R41-R54 = 47k).
I had the same problem as Funky40, but now it's working fine.
btw, anyone managed to get the X-Pan working with +/- 12V?
At +/- 15V it's working but I get no sound when it's connected to my +/- 12V PSU. I think I have to change some resistor values .... ??
PostPosted: Thu May 07, 2009 11:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Rvlt wrote:
hi everyone,
thank you so much for thiat pointer! i will correct the BOM today.
and you are right about the schematic. the circuit diagramm is the original, the BOM is edited so could contain errors (it shall not of course!).
this issue reminds me of the EFM stuff. it can become annoying.
i will try tonight. i actually cannot see why it shouldn't work with 12V!?
PostPosted: Thu May 07, 2009 11:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
documentation updated:
http://www.modular.fonik.de/pdf/PS3100_DT_v3.pdf
TekniK
PostPosted: Thu May 07, 2009 11:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Rvlt wrote:
hi everyone,
Huh!,damn fuck,thats why i hate those DIY DS PCB's.
Waste of time to fix that on 10pcb's,pff.. Sad
BOM's and list sucks,make a component layout with the values writed into it and not r4,c8 etc..,how more intervals how more risk to errors,its well known.
It takes the same time to search for r4,rx and rz as to search all 100k for example on a pcb so
Lists are good to see how much u have to order,but not as a refference to
build!
Thumb down
PostPosted: Fri May 08, 2009 12:06 am    Post subject: Reply with quote  Mark this post and the followings unread
TekniK wrote:
Rvlt wrote:
hi everyone,
i absolutely understand your anger about that. i am very sorry.
i can see the point in it. just numbering the parts makes the board more generic, though. you could easily change parts values afterwards by editing the BOM (field changes).
but i take your point. for the next project i will try to incorporate a silkscreen of the PCB into the documentation containing the values...
gwaidan
PostPosted: Fri May 08, 2009 7:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, are there any boards still available? I'd really like to get one of each board if possble...
PostPosted: Fri May 08, 2009 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
the PS3100 PCBs are sold out, some x-panner boards are left. i think i will reorder some PS3100 next month.
Funky40
G2 patch files: 5
PostPosted: Fri May 08, 2009 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Rvlt wrote:
hi everyone,
thanks alot !
I fixed my X-Pan module, and its working fine now.
It's another nice FM experimentation Module.
PostPosted: Fri May 08, 2009 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
mea culpa, mea maxima culpa.
but i am glad it works now, mr funky.
Funky40
G2 patch files: 5
PostPosted: Sat May 09, 2009 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
haha, de nada
Yeah me too, and thanks again.
I think there are quite some nice patch possibilytis with this one.
Might be fun to have two of it Wink
Rvlt
PostPosted: Sun May 10, 2009 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey fonik,
did you find time to try it out?
Before I changed R41-44 to 100k AND using +/-12V the only sound coming from the X-Pan was the "wrong" VCA-Channel (IC1 D). So I **guess** it's only a matter of choosing the right values for transistor gain... But what resistors and what values?
Rvlt
PostPosted: Mon May 18, 2009 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Uups,
I think I found another mistake in the BOM:
CV section:
R53, R54, R57 and R58 should be 100k (NOT 47k)
Output section:
R45-R52 should also be 100k (NOT 47k)
I changed that, but I think there's not much of a difference..
+/- 12V solution:
I changed R9, R20, R31 and R41 to 78,7k and now the behaviour is the same as with +/-15V.
PostPosted: Mon May 18, 2009 11:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Rvlt wrote:
Uups,
CV section:
Output section:
actually no difference at all (besides the range of the manual pot).
however thanks for pointing this, will be corrected soon.
+/- 12V solution:
R42 instead of R41 Wink
thanks for telling us.
TekniK
PostPosted: Mon May 18, 2009 11:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Rvlt wrote:
Uups,
CV section:
Output section:
plz,i almost did get an heart-attack here
PostPosted: Mon May 18, 2009 11:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
me too.
it is not the 1st time i did a PCB run and building docs, as you all might know, and all went quite fine, i would say. i don't know what happened to the panner docs Shocked
(BTW new edition of building docs just uploaded - sorry for the inconvenience)
Rvlt
PostPosted: Tue May 19, 2009 4:40 am    Post subject: Reply with quote  Mark this post and the followings unread
oh, those mistakes ... Very Happy Very Happy
btw, I noticed i fairly high amount of the CV-signal (DC) present at the audio outputs. I saw it on the meters of my mixing desk, even when there was nothing connected at the audio-in.
Or hear it when you modulate the xpan with a square or sawtooth: "click click click ..."
anyone knows how to get rid of it?
I read about ac-coupling and put a cap at the output, but dc was still there...
ok, thanks
TekniK
PostPosted: Tue May 19, 2009 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, thanks
Shocked
Ok,stop plz now amgonna throw away all this pcb's for garbage
LektroiD
PostPosted: Tue May 19, 2009 5:37 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, thanks
Shocked
Just wait until the new docs are posted, or throw them My way, I'll gladly pay you the postal fare for them Wink
LektroiD
PostPosted: Tue May 19, 2009 7:02 am    Post subject: Reply with quote  Mark this post and the followings unread
@rvlt
for now i don't know.
to remove DC you could in any case at the output add a say 22uF cap followed by a 100k to GND. but that would be a workaround. however this is not a top notch VCA system but a dirty solution originally meant as expansion for the resonators. therefor i left oft some trimmers.
i tested and built it for 15V operation and could not find recognizable offset on the output.
again, we will find a solution for your problem.
@teknik
i absolutely understand that you are totaly pissed off by now. i still could refund you, if desired. just let me know. the last thing i wanted to happen was to take the fun out of it - too late, it happened.
PostPosted: Tue May 19, 2009 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
rvlt, i measured the outputs of the panner again tonight. both show almost no offset at all, as long as no modulation source is connected. when i move the manual pan control or use a LFO i can measure a absolute max. negative offset up to -0.5V. that doesn't hurt me.
for now i would suggest the filter method: cap + resistor to GND (see above).
i will think about it. you are running it at 12V?
TekniK
PostPosted: Tue May 19, 2009 3:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
@teknik
hey i was jokin' mate, u should know me now..
but i hope i don't have those offsets ofcource
damn,always problems with those germans (since WWI) Wink
Rvlt
PostPosted: Tue May 19, 2009 6:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey fonik,
thanks for your support.
yes, I got two xpanner working at 12V.
I tried a 22uF cap in series together with 82k resistor to gnd (100k were all gone), but lfo-signal was still present at the audio-out.
I will (temporarily) try with 15V tomorrow and let you know ...
gwaidan
PostPosted: Wed May 20, 2009 6:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry if this seems a bit basic or it's been thought of before, but I've thought of a possible cause of the offset problem...
What I think is happening here is that when there is no audio input in the panner circuit the base of each input transistor is connected to ground via a 1k resistor but the base of each reference transistor is connected directly to ground-as the bias current through the 1K resistor leads to a voltage drop there is an offset voltage between the two bases, giving a difference in collector currents (and differential amplifier terminal voltages) which is modulated by the control voltage to create audible feeedthrough.
If this is correct then breaking the tracks connecting the bases of Q2, Q5, Q8 and Q11 to ground and soldering a 1k resistor across each break should make a difference...
(edited to minimise waffle)
TekniK
PostPosted: Wed May 20, 2009 7:02 am    Post subject: Reply with quote  Mark this post and the followings unread
