ReaktorFreak
Joined: Sep 28, 2007 Posts: 65 Location: Jakarta, Indonesia
Posted: Fri Oct 10, 2008 1:17 am Post subject:
How to control PitchBend Range ? |
| I'm kinda stuck here, is there any way to adjust PitchBend range on a device via MIDI ? For example, changing from -2 to +2 semitones to one octave just by sending MIDI message ? |
BobTheDog
Posted: Fri Oct 10, 2008 3:31 am Post subject:
I don't think there is a standard for this.
What are you trying to set it on?
Andy |
ReaktorFreak
Posted: Sun Oct 12, 2008 11:06 pm Post subject:
| I just think maybe there's a trick to do it, as i can't find any CC for that. I read in other forum that it can be done with RPN, but it says not all device compatible with it. It's just annoying, the -2 to +2 standard is not suitable for guitar, and i think if there's a way of changing it, i can put that inside the MIDI file i made. |
BobTheDog
Posted: Sun Oct 12, 2008 11:14 pm Post subject:
I must admit I tend to set the pitch-bend range on a patch basis on the synth I am using.
If you are a midi guitar player may I direct you to the new Sub-Forum "Strings And Things" http://electro-music.com/forum/forum-172.html
Andy |
svivens
Posted: Mon Oct 13, 2008 7:16 am Post subject:
you can try the change scale patches from Sensomusic Usine...
it takes the incoming MIDI values,treat them regarding the min and max you select,and create the apropriate values out.
i'm sure you can do the job with this.
it's Standalone or VST, and free!
Usine4 free |
ReaktorFreak
Posted: Mon Oct 13, 2008 10:36 pm Post subject:
| BobTheDog wrote: | I must admit I tend to set the pitch-bend range on a patch basis on the synth I am using.
Andy |
Hey, thanks for letting me know about the new sub-forum. I'm not exactly playing MIDI guitar though.
| svivens wrote: | you can try the change scale patches from Sensomusic Usine...
Usine4 free |
Thanks ! I'll have a look immediately. |
ReaktorFreak
Posted: Sat Apr 04, 2009 9:35 am Post subject:
Finally got it, although not quite understand the meaning of them. It's kinda lucky find i think..
CC6 - 64
CC6 - 24 -> PB Range
CC38 - 0
CC38 - 0
CC98 - 9
CC99 - 1
CC100 - 0
CC101 - 0
This can be quite useful especially for changing pitchbend range on an uneditable patch, such as GM ROM bank. I've tried it on my soundcard wavetable GM ROM bank that has the SMF fixed default of -2 to +2 pitchbend range, and now it can have -24 to +24 range, which i think was not possible before. |
