bass/kick drums
Page 2 of 2 [32 Posts]
Goto page: Previous 1, 2
kijjaz
PostPosted: Tue Oct 21, 2008 3:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I've just design a quite simple one with these feature:
Main drum body is main with Impulse and LPF again!
Added Noise with decay to simulate the beating sound and noisy vibration
Feed the Noise into a filtered Karplus-Strong algorithm (feedbacked delay) to simulate how the sound travels and loop in the bassdrum.
The model is still in testing (but shouldn't be any dangerous if the filter values are set properly).
Haven't created into a class, but now should work easily by playing with the im impulse's next function.
Sound can differ very much between different sample rates because the way to implement decay.
20081021kijjaz-BD1.ck
kijjaz's Bass Drum 21 Oct 2008 revision 01 prototype
 Filename:  20081021kijjaz-BD1.ck
 Filesize:  1.29 KB
 Downloaded:  371 Time(s)
Inventor
Audio files: 267
PostPosted: Tue Oct 21, 2008 9:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Well done, kijjaz, the drums sounded perfect to me, but when I looked on the scope our clipping waveform wasn't there. So I added a limiting dyno with gain and got back the clipping.
Now, thanks to your noise and feedback and all that kewl stuff, we have a waveform very much like the one in the photo. It starts out with clipping noise and settles into a clipping sinosc, which then decays into an unclipped sinosc. So all of the waveform features are there.
It sounds a bit harsher and cruder with the clipping, but that is what is in the rock songs I listen to. Also note that I added "Gain sum" - the rest of the music should be piped into that summing amp so it gets clipped properly. Do you like my little change?
20081021kijjaz_les_bd1.ck
kijjaz's LPF drums with clipping restored
 Filename:  20081021kijjaz_les_bd1.ck
 Filesize:  1.36 KB
 Downloaded:  344 Time(s)
rogan
PostPosted: Tue Oct 21, 2008 8:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sweet sounds. I like what I'm hearing!
Inventor
Audio files: 267
PostPosted: Tue Oct 21, 2008 8:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, kijjaz added his magic percussion dust all over that one, didn't he? I just had to add gain and clipping to get it back to where it should be, me having a scope and all. I wonder what magic kijjaz will do next? Haha!
rogan
PostPosted: Tue Oct 21, 2008 9:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, man. I got a silly one for you all.
Code:
// Bass Drum 21 Oct 2008 revision 01 prototype
// Copyright 2008 by Kijjasak Triyanond
// This software is protected by the GNU General Public License
// initial values
// bass drum body
Impulse im;
 HPF hpf => LPF lpf => Dyno limiter => SinOsc od => dac;
im => Gain g => Gain g_fb => g => hpf;
g_fb => Gain g_fb_fb => g_fb;
0.5 => g_fb.gain;
50 =>hpf.freq;
100 => lpf.freq;
pi => lpf.gain;
limiter.limit();
limiter.thresh(.1);
limiter.ratio(1000);
limiter.attackTime(30::ms);
55 => limiter.gain;
od.sync(1);
// test code:
.25 => float velocity;
while(true)
    velocity => im.next;
    second => now;
    .25 +=> velocity;
    if (velocity > 1) .25 => velocity;
Maybe not drum-y, but the feedback makes the OD sine sing.
chuckbeginner
PostPosted: Tue Oct 21, 2008 10:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
This doesn't sound great through my headphones, but it sounds okay on my speakers. I think it's a passable four-to-the-floor kick for a house song.
Y'all are amazing. Thanks for all the encouragement and feedback.
house_beat.ck
 Filename:  house_beat.ck
 Filesize:  281 Bytes
 Downloaded:  302 Time(s)
house_beat.ck
 Filesize:  281 Bytes
 Downloaded:  326 Time(s)
chuckbeginner
PostPosted: Tue Oct 21, 2008 10:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not silly, man.
There are lots of percussive sounds that are cool. I'm pretty much interested in them all. I can definitely imagine that sound being on an early 80s hip-hop/electro track (and I love that era/sound).
Code:
// initial values
// bass drum body
Impulse im;
0.5 => g_fb.gain;
50 =>hpf.freq;
100 => lpf.freq;
pi => lpf.gain;
limiter.limit();
limiter.thresh(.1);
55 => limiter.gain;
od.sync(1);
// test code:
while(true)
    second => now;
    .25 +=> velocity;
