pinealapoptosis
Joined: Nov 07, 2008 Posts: 104 Location: Southeast US
Posted: Thu Nov 13, 2008 7:28 pm Post subject:
A6 Banker problems |
Hey everyone.I just downloaded the registered version of A6 banker.I cannot get it to install for the life of me.
When I unzip the files and try to open the .exe file,I get that standard windows xp error message.
I tried making a program folder for it.No dice.
I tried downloading the trial version then unzipping the reg. version into the trial version program folder.No dice.The trial version installs but even it wont run the .exe
Mark sent me copy of the .exe file that wasnt compressed.This gave me the same error message when I opened the .exe file.
I have tried this on 2 computers.Both running windows XP.One has sp2 and one has sp3.
Mark has been trying to hep via email but we have gotten no where.
I figured I would post my problem on here just to see if anyone experienced this same problem and if so,how did you resolve it?
Thanks _________________ The Gnomes have learned a new way to say Hooray |
pinealapoptosis
Posted: Thu Nov 20, 2008 10:18 pm Post subject:
Well,it seems you must have a midi interface plugged in to run the banker.exe program.
I bought an m-audio fast track ultra and am unhappy.So I am and sending it back and my new Tascam US-1641 is on its way.I think I will be happier with this.
So I will post an update about my banker problem when my new interface gets here.
Cheers _________________ The Gnomes have learned a new way to say Hooray |
sunny pedaal
Joined: Nov 16, 2004 Posts: 735 Location: netherlands
Audio files: 12
Posted: Fri Nov 21, 2008 2:17 am Post subject:
yes the midi-interface used is important espec when handling sysex data.
i have good experience with motu and rme |
ThreeFingersOfLove
Posted: Fri Nov 21, 2008 6:49 am Post subject:
Indeed, the MIDI interface must be switched prior to launching the Banker executable. I have discussed with Mark about this and he said it's just a side-effect of how he coded the application.
Regards,
Yannis |
husker
Joined: Apr 30, 2008 Posts: 32 Location: wellington.newzealand
Posted: Fri Nov 21, 2008 3:55 pm Post subject:
| if you *really* want to run it without a midi interface, then it should work with MidiYoke installed...as long as the app sees some midi ports |
pinealapoptosis
Posted: Fri Nov 21, 2008 10:43 pm Post subject:
Thanks for the midiyolk info.
Since an interface like the tascam 1641 has midi in/out ports,does this mean I dont need a midi interface.Or do audio interfaces with midi in/out work as a midi interface as well? _________________ The Gnomes have learned a new way to say Hooray |
husker
Posted: Sat Nov 22, 2008 1:46 am Post subject:
| in theory the Tascam will be fine as a midi interface - some interfaces can not cope that well with the sysex transfer... you'll just have to try it and see |
pinealapoptosis
Posted: Sat Nov 22, 2008 2:42 pm Post subject:
Ok great.Thanks for the help.
I think the fast tarck ultra sucks when it comes to midi.
I cannot get a6 banker to run with it either.
Maybe I will have better luck with the Tascam _________________ The Gnomes have learned a new way to say Hooray |
ThreeFingersOfLove
Posted: Sun Nov 23, 2008 1:42 am Post subject:
| apoptosis wrote: | Ok great.Thanks for the help.
Maybe I will have better luck with the Tascam |
If you have problems with the transmission try increasing the SYX-DLY parameter because the Andromeda chokes when it's fed sysex very fast.
Regards,
Yannis |
doperobot
Posted: Mon Aug 24, 2009 9:00 am Post subject:
| also, you need to install the non-registered version first, and then install the registered version over the top of it. |
