RAY'S SIMPLE PORTAMENTO
haxster
PostPosted: Wed Feb 18, 2009 1:35 am    Post subject: RAY'S SIMPLE PORTAMENTO Reply with quote  Mark this post and the followings unread
This is easy to build. It was extracted from ray's sequencers. It is confirmed working with Soundlabs and other DIY VCO's.
The TL072 is just a buffer for multiple CV outs, if you needed more use a TL074 and repeat the OP-AMP pattern (All +inputs connect).
If you were going to add this to a soundlab internally (MOD), you have to add 100K resistors to the CV outputs and then connect at "AA" or PIN 6 on each vco. If you look on the schematic on PIN 6 it looks like a tree of 100k resistors for each CV. That's were you tap in. Your adding another 100k branch.
 Filename:  SIMPLE PORTAMENTO.bmp
 Filesize:  385.06 KB
 Downloaded:  1149 Time(s)
