Shepard function generator?
Page 1 of 1 [4 Posts]
fluxmonkey
PostPosted: Wed Mar 18, 2009 8:20 am    Post subject: Shepard function generator? Reply with quote  Mark this post and the followings unread
has anyone implemented a Shepard Function (http://machines.hyperreal.org/manufacturers/Paia/images/shepard.txt) generator in arduino or similar? seems like a natural...
bbob
www.fluxmonkey.com
JovianPyx
Audio files: 224
PostPosted: Sun Apr 12, 2009 9:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not to let any air out of your balloon, but while I've not done this with an Arduino, I've done it with a Roland D-110. It is was a curiousity to listen to, but really underwhelming in the long run.
It was a psychoacoustic effect that made me go wow for a short moment and then on to other things.
Yes it sounds like the pitch of the "tone" rises forever - sorta - but if you listen to it long enough, you can pick out what is really happening and that realization causes the effect to melt down. At least it did for me.
Time flies like a banana.
corruptio optimi pessima
fluxmonkey
PostPosted: Mon Apr 13, 2009 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
yr probably right abt the constantly rising (or falling) tone being a one-trick pony... i was thinking abt the buchla barberpole modules, which i believe use shepard functions as CVs in more complex contexts...
b
www.fluxmonkey.com
synthmonger
PostPosted: Thu Dec 10, 2009 8:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Boss Phase Shifter PS-3 does the Barblepole effect. It's easy to modify every parameter for CV control...I really need to get around to modding mine.
Youtube!
modular demos!
Whacky tunes!
