today> Twyndyllyngs reschedule: Sunday, Dec 7 Chez Mosc
cgs58 lfo cv->speed?
Page 1 of 1 [17 Posts]
wetterberg
PostPosted: Sat Mar 28, 2009 1:45 pm    Post subject: cgs58 lfo cv->speed?
Subject description: - can it be done?
hey all,
I was hoping to find this mod described in this forum but no luck, apparently...
is it possible to inject CV into this circuit to control the speed of the LFOs?
Perhaps mixing the wiper output from the Speed potentiometer with incoming CV? From what I understand that pot. is basically acting as a voltage divider here, right?
Any help would be awesome. I know I should probably experiment with low-voltage DC here, but I really don't want to fry up shit on a whim like in my circuitbending days Wink
andreas
andrewF
PostPosted: Sun Mar 29, 2009 5:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
this question is asked regularly, but I cannot recall anybody offering a solution....except perhaps building a VC LFO from another source. This cct was never designed to be CV controlled.
I don't think injecting a CV signal to the wiper of the 'speed' pot will help. This pot is processing the output of the Schmitt trigger stage, not a CV or DC voltage.
A possiblity would be a LDR/LED combo or vactrol, with the LDR connected between the speed pot's wiper and the node of the speed pot and the 4k7 resistor or maybe to pin 8? There are plenty of ccts out there for driving a vactrol with a CV signal.
It would be hard...impossible... to get precise control and the degree of control from the CV signal would be affected by the setting of the pot.
have fun Very Happy
wetterberg
PostPosted: Sun Mar 29, 2009 6:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers, Andrew.
You know, I would have thought so too, but for the life of me I can't find the threads for those mods? Confused so weird.
Yeah, I already have some (four, I believe) vactrol circuits from Bridechamber ready to roll, so that's always a possibility - I'm not looking for precise control in any shape or form, just a nice way to freak the LFO out, really.
I have two Doepfer 147 vcLFOs, which crossmodulate in the nicest of ways - lfo out->cv in->lfo out->cv in, that sort of thing. Really simple, actually.
Righto, I'll build these up, then go nuts with the DMM/scope to see what I can do with this.
electang
PostPosted: Mon Mar 30, 2009 5:07 am    Post subject: Reply with quote  Mark this post and the followings unread
You 'll be satisfied. Smile I have tested this and it does vc control the frequency but at the expense of a tremendous and continous drift making it useless as vc clock Crying or Very sad
wetterberg
PostPosted: Mon Mar 30, 2009 6:15 am    Post subject: Reply with quote  Mark this post and the followings unread
good to know! Very Happy
And thanks for the info re. stability under vactrol control - I'll be sure to add a switch to punch it in or out.
synthmonger
PostPosted: Mon Mar 30, 2009 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
What current source are you using to drive the vactrol? I've used an expo and linear transistor source with very minimal drift, only a punchy glide..though I may be wrong I haven't tried it out in quite a while. I used a fast vactrol too. I do find vactrols to be useless when controlling oscillators because of the slight attack. Fun with noise gizmos, but vcos and lfos I'll pass.
electang
PostPosted: Tue Mar 31, 2009 12:53 am    Post subject: Reply with quote  Mark this post and the followings unread
[quote="synthmonger"]
I just used the Bridechamber pcb
synthmonger
PostPosted: Tue Mar 31, 2009 1:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Did you use the vactrol he sells? That's a slow resistor you may wanna up it to a VTL5C4 i think thats the fastest.
electang
PostPosted: Tue Mar 31, 2009 4:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I use VCTL 5C3/2
I dismantled this circuity so I cannot do further test
maybe my mistake was wanting to use it as a VC clock
otherunicorn
PostPosted: Mon Apr 06, 2009 1:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Quite frankly, I wouldn't bother trying to voltage control oscillators using this core. That is why I called it the utility LFO i.e. plain, minimum options. You really need a ca3080 at the core instead of plain old op-amps. One day I''' get around to it, but don't hold your breath. You are better off just using a VCO with a divided output, or running really slow.
http://www.cgs.synth.net/
wetterberg
PostPosted: Mon Apr 06, 2009 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your input Very Happy
However, I'd say a dual utility LFO with two vactrol-ish things attached is a MUCH MUCH MUCH easier build than building two VCOs Shocked
- again, I'm not looking for precision, 1v/oct, ANY sort of proper tracking, really - not even temporal precision with varying cv input - think more wogglebug, less proper control Wink
*IF* that fails I'd love some pointers on how to do a stripped build of your VCO - that would certainly come in handy.
andrewF
PostPosted: Mon Apr 06, 2009 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
That would be Richard Brewster's version -
http://pugix.com/synth/cgs-vco-project/
wetterberg
PostPosted: Mon Apr 06, 2009 6:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
cheers. hmmm. I've been over there before... I wish there were a less techy approach, though. CGS-as-seen-from-the-noob, as it were. I guess that'll have to be me Wink
bugbrand
PostPosted: Tue Apr 07, 2009 2:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey - check out the CA3080 cookbook from Thomas Henry (available from Magic Smoke, I think?) - the VCO design is basically the standard utility LFO design but with an OTA replacing the manual speed control. You could, of course, make a double using an LM13700.
Actually the THVCO1 is this sort of design:
http://mypeoplepc.com/members/scottnoanh/birthofasynth/id33.html
...though it uses a discreet transistor based comparator section (opamp in the standard utility LFO design)
http://www.bugbrand.co.uk
zthee
PostPosted: Tue Apr 07, 2009 1:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just skip the orange parts and you got a simple VCO Smile
Though the to part might be fun to have.. Since you can invert the gain of incomming CV banana
 Filesize:  24.37 KB
 Viewed:  417 Time(s)
ericcoleridge
PostPosted: Fri Apr 24, 2009 6:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
For me, I would have more use with a sync/reset input on the utility LFOs; I'm wondering if there would be a 'simple' way to implement sync? I know that I've accomplished a reasonable reset on my MFOS LFO by just inserting a gate signal at the timing capacitor.
Of course there's tons of LFOs out there that are designed with sync, VC, etc. But, I particularly like these Utility LFOs, for a number of reasons. They remind me of the LFOs on the MS20.
wetterberg
PostPosted: Sat Apr 25, 2009 2:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I did read a description about how to do a reset with the Utility LFOs - I believe it's on this forum, too?
