Posted: Tue Mar 31, 2009 5:48 pm Post subject:
Nintendo DS Subject description: Touch, Wifi, dual ARM processors, and two expansion ports |
Ok, so this isn't an apple product, but sits in the exact same class, and much of the development work that went into the Nintendo DS as a music machine was then ported to the iPhone later on.
I'm in the process of adding a hardware midi port, rather than wifi, so I can avoid having a computer around all the time. It's through an SPI port, so easy to interface to, and there's cheap hardware available to do this.
Links:
http://www.nintendo.com/ds
DSMI (offers MIDI and OSC via WiFi)
http://dsmi.tobw.net/forums.html?cat_id=1
Hardware Interface (debug, MIDI, SD card storage) (the DSMI lib above supports this card)
http://www.electrobee.com/dserial-edge-p-45.html
Tools for writing your own programs
http://www.devkitpro.org/
Technical Reference:
http://www.bottledlight.com/ds/forums.html
10.91 KB |
| Viewed: |
6378 Time(s) |
iPassenger
Joined: Jan 27, 2007 Posts: 1070 Location: Sheffield, UK
G2 patch files: 78
Posted: Tue Apr 07, 2009 7:44 am Post subject:
Not that I know of. This is what I've put together, though it may not be accurate:
Supposedly OSC doesn't need DSMIDI at all, since it is already a network protocol, and TX and RX machines already know how to construct and deconstruct OSC packets, and use the same port#. DSMIDI (the client on your computer) just talks it's own midi packets. However, the DSMIDI library provides the OSC support to applications.
I'm notsure if it's RTP-MIDI compatible (RTP MIDI is an open standard to transmit MIDI over LAN, which Apple uses for midi over lan).
http://www.cs.berkeley.edu/~lazzaro/rtpmidi/ |
BobTheDog
Posted: Tue Apr 07, 2009 8:08 am Post subject:
| iPassenger wrote: | jksuperstar,
Will this DSMIDIWifi Server convert OSC data into Midi for me on my pc?
R. |
On a PC it seems its a bit DIY, have a look at PureData http://code.google.com/p/oscemote/wiki/OSCemotePureDataTutorial
MAX, Reaktor or Bidule will also let you do this sort of thing. |
iPassenger
G2 patch files: 78
Posted: Tue Apr 07, 2009 9:46 am Post subject:
Cheers for the responses, this is as I thought, nice if there was something a bit simpler that required less seperate programs (and thus pc resources).
Might try yr dsmidi thing though.  _________________ iP (Ross)
