How To Get One Keyboard To Play The Sounds Of Another ?
Page 1 of 1 [10 Posts]
worldwalker
PostPosted: Mon Apr 13, 2009 12:26 pm    Post subject: How To Get One Keyboard To Play The Sounds Of Another ?
Subject description: Not a noob, not yet a woman.
I need to find out how to get one keyboard to play ..
Well.. my problem is already desribed in the topic, so no need to do that again.
i know that the procedure is different for all the different kind of keyboards, what i really need is some hints as to where i should make some sort of general connection between the two, if such a thing is possible.
So if you are reading this and has some input on the matter. please write.
Thanks
Maartin
BobTheDog
PostPosted: Mon Apr 13, 2009 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome
How about a midi lead:
http://www.leadsdirect.co.uk/productinfo/midileads.html
Sam_Zen
PostPosted: Mon Apr 13, 2009 5:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Welcome.
I'll skip software solutions like MIDI for the moment. The hardware situation :
When coupling two keyboards together, it's necessary to have the circuit design of both.
And check out how the actual keys are doing their job. Every key is a switch.
Switches can be bridged by another switch.
This could be complicated, needing a galvanic separation, or simple.
If a key means a connection to ground in the circuit, a bridging could be done by connecting one key via a diode to the other key-point.
Of course the ground of power should be common.
Lofi Ninja
PostPosted: Tue Apr 14, 2009 2:14 am    Post subject: Reply with quote  Mark this post and the followings unread
You can do it without circuit bending anything aswell..
You need a Ringmod.. Here's a vid I made with 2 keyboards and a DIY passive ringmod. You can control the pitch aswell..
One keyboard should output something, say a drum pattern
and then you use the other keyboard to control that.. Anyways have a look..
www.youtube.com/user/lofininja
worldwalker
PostPosted: Mon Apr 20, 2009 4:21 am    Post subject: thx Reply with quote  Mark this post and the followings unread
Thanks for the suggetions and help people.
Now im off to get a ring mod.
But first: to learn what it is called in Danish
Lofi Ninja
PostPosted: Mon Apr 20, 2009 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Build your own instead!
The one I built is this one:
http://www.cgs.synth.net/modules/cgsrr.html
If you want a comercial one your probably only going to find the Moog Moogerfooger102 at 300 USD.. Crazy expensive..
http://www.moogmusic.com/moogerfooger/?section=product&product_id=6
I think the only difference of the moogerfooger and the DIY one is that it has a built in LFO on the carrier... You can build that yourself aswell..
worldwalker
PostPosted: Mon Apr 20, 2009 1:04 pm    Post subject: . Reply with quote  Mark this post and the followings unread
i will try that out.. i also heard that some old radios has a ring modulator inside them .. Though i have yet to see what they are all about
Lofi Ninja
PostPosted: Mon Apr 20, 2009 3:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure about them having an actual ringmod inside them, but many older boomboxes and radios have audio transformers inside. Just the other day I took apart an old ghettoblaster/boombox from the 80's and it had 2 pairs of audio transformers inside.. Score.. You don't need the specifications to be super close to the ones used on the site.. The pair I used for my ringmod was not close to those specs. But keep the pairs identical and it should work just fine. Also germanium diodes are not a must-have, but they will make a much better sound. I used silicon becase I didn't have germanium..
stolenfat
PostPosted: Thu Apr 23, 2009 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
im glad some one finally confirms that you dont need geranium diodes. never tried the passive ring mod cause i never could find no geranium diodes.
thanks lofi!
badstatic
PostPosted: Sun Sep 06, 2009 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can quite often 'cross modulate' digital gear with other digital gear such as casio sk's / roland tr-505's / alesis and kawai drum machines, etc..
You just need to connect the machine's sound roms to each other (with something metal like a wire), and play about until you find something that sounds cool. .
I can use my casio sk to 'play' my various drum machines on an electronic level. The sound which comes out is totally unlike either the drum machine or the SK !
Search youtube for - 'alien cross-modulation casio sk-5' for a rather extreme example of some of the sounds you can get.........
This is where you'll see the advantage of a 'bolt-bay' or one of those ugly looking (is it an audio cable or isn't it?) RCA patchbays. Just remember to connect the GROUND of both machines together, or it won't work.
