 Forum index » Clavia Nord Modular » G2 Performances - Noodles
improvisation
Page 1 of 1 [4 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sun Sep 19, 2004 4:37 pm    Post subject: improvisation Reply with quote  Mark this post and the followings unread
I have been using the RndTrig module in combination with the Pulse(logic) for a while. This noodle uses these in combination with the ZeroCnt module. When a Trig is 'dropped' the ZeroCnt output changes which is used to modulate the pulse time (through an inverter).
quart.prf2
an improvisation
 Filename:  quart.prf2
 Filesize:  11.49 KB
 Downloaded:  1867 Time(s)
Audio files: 227
PostPosted: Sun Sep 19, 2004 5:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like this one, Ian. It sounds like an ensemble of real instruments and real musicians. Shocked
Audio files: 227
PostPosted: Sun Sep 19, 2004 6:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow - after about 1/2 hour the bass player takes a solo. Amazing...
Roland Kuit
G2 patch files: 127
PostPosted: Mon Sep 20, 2004 2:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool!
