today> Sorry, no program tonight. Chez Mosc
Repulsor Sound from 2 chips
Page 1 of 1 [10 Posts]
PostPosted: Thu Jun 18, 2009 3:47 am    Post subject: Repulsor Sound from 2 chips Reply with quote  Mark this post and the followings unread
Yesterday, I was researching a circuit to power the blue LED electrostatic repulsors which I plan on incorporating into a scratchbuilt model of a hovercraft ship, inspired by the Nebuchadnezzar from the Matrix movies.
It's just 4 * 40106 free running oscillators, approx 15hz each with the outputs sent to 4 * XOR gates so that the gates are run from oscillators - 1&2, 2&3, 3&4, 4&1
With a LED on each output, held close together, they look like a semi random pulsing blue light which is just right.
Of course I'll need at least 4 LEDs in each of 8+ replusor drives, so the whole idea will be scaled up,.........
But,..........
I decided to have a listen to what it sounded like, and I've got to say I was very impressed.
Instead of simply mixing the outputs, I added them together in a simple 4 bit R/2R network.
Then,..... in an effort to "slide" the transition of each bit inside the R/2R, I put a 100nF cap around each of the R segments. (I'm using 10K/20K)
And the result?
A sound which sounds exactly the way I wanted it to look!!! Shocked Very Happy Very Happy
In fact, if I can somehow add audio transducers to the model, I think I will, as it would be the icing on the cake to "hear" the blue glow of these repulsors as well as see them.
Here's an mp3. No effects. Not even an op-amp buffer! DC coupled straight off the MSB!! Very Happy
Repulsor.mp3
 Filename:  Repulsor.mp3
 Filesize:  141.53 KB
 Downloaded:  1967 Time(s)
RF
Audio files: 28
PostPosted: Thu Jun 18, 2009 4:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Sweet, Krunkus!
I agree - that's just about perfect!
bruce
www.sdiy.org/rfeng
PostPosted: Thu Jun 18, 2009 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I just tried replacing the 100nF caps with 470nF, and I think it's even better. More rounded bottom end.
The way the caps interact with the fluctuating bits in the R/2R is really nice. I can hear occasional flanging / phasing of the XOR PWM effect, but it's more than that. It's like the caps don't know if they're charging or discharging, cos they're bleeding into each other, and in and out of the XORs.
It almost sounds like it has a nice resonant filter built into it.
It would be debatable as to how "musical" this sound could be made.
I s'pose it just depends on how much you control the oscillators, which I'm not doing at all. The only reason this sounds as complex as it does is the tolerance on those 40106 oscillator caps and resistors.
If anyone wants a schem, I can knock one up pretty quick.
RF
Audio files: 28
PostPosted: Thu Jun 18, 2009 5:08 am    Post subject: Reply with quote  Mark this post and the followings unread
If you are willing to draw it - do it! I may or may not build it, but it would be interesting to see the circuit...
Thanks
bruce
www.sdiy.org/rfeng
PostPosted: Thu Jun 18, 2009 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Here ya go,
 Filesize:  16.4 KB
 Viewed:  696 Time(s)
RF
Audio files: 28
PostPosted: Thu Jun 18, 2009 6:47 am    Post subject: Reply with quote  Mark this post and the followings unread
TU Uncle Krunkus!
It would be interesting to play with this at higher frequencies - or for your application, set them initially a tad higher and then controlling the frequency slightly by the v+ on the 40106.
You know - that old here come the "squidies" - "power up the repulsors and get out of here!"... thing.
bruce
www.sdiy.org/rfeng
slacker
PostPosted: Thu Jun 18, 2009 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks interesting I'll give that a try.
droffset
PostPosted: Fri Jun 19, 2009 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's cool, I need one.
PostPosted: Sun Jun 21, 2009 4:35 am    Post subject: Reply with quote  Mark this post and the followings unread
By adding these four 240K resistors, I've managed to make each oscillator "bleed" some current into the next one's capacitor. Thereby creating this kind of cyclic syncing effect which makes the waveform more regular, but with unpredictable shifts in timbre.
Oh, hold on, (I'm listening to it through headphones right now) and it seems like after about 10mins it's finally dropped into a locked state.
Okay, well I didn't see a locked state when the resistors were up around 270K. That might be a better value.
I've also noticed that the stability is affected by what you do with the two unused buffers. I've currently got them figure 8 style with two caps. I'll fix that bit of the pic later.
 Filesize:  18.84 KB
 Viewed:  651 Time(s)
synthmonger
PostPosted: Fri Jul 10, 2009 10:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Did you try replacing the resistors for diodes in either direction? Or R+D combo? I use those for a sync effect with a whacky vco im working on as one of the 40106 inverters as the core.
Youtube!
modular demos!
Whacky tunes!
