 Forum index » Clavia Nord Modular » G2 Patches - Completed » Sequencer - interactive
oddseq
Page 1 of 1 [2 Posts]
egw
G2 patch files: 8
PostPosted: Fri Oct 22, 2004 4:05 pm    Post subject: oddseq Reply with quote  Mark this post and the followings unread
Oddseq is a pattern based sequencer that can be adjusted using the keyboard. By default it plays a random sequence of any notes. However, the key quantizer is set by the upper ocatve of the keyboard. If you play a note with velocity >64, that note will be allowed in the sequence. Playing a note with velocity <64 removes it from the sequence. The lower two octaves of the keyboard will transpose the sequence up or down (with no change at middle C).
This patch must be loaded in slot B.
Knobs are as follows (row A only):
notes dice, rhythm dice, filter, octave, length, pattern, volume.
Patterns selected using the dice can't be saved. If you want to save patterns, use the pattern select knob.
Volume is down when the patch is loaded. The variations are not programmed.
oddseq.pch2
 Filename:  oddseq.pch2
 Filesize:  3.65 KB
 Downloaded:  2594 Time(s)
Audio files: 224
PostPosted: Fri Oct 22, 2004 4:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
This one is very cool. Takes some time to get used to it, but not all that much time. Laughing
