note offs not working
Page 1 of 1 [3 Posts]
twist3d
PostPosted: Mon May 10, 2010 5:02 am    Post subject: note offs not working Reply with quote  Mark this post and the followings unread
hi all, i'm doing a rendition of tetris using chuck for a uni project, but i can't seem to get the note offs to work. can someone help me with this please?
Thanks in advance Smile
here's my code so far:
Code:
// Declarations
Envelope EnvMaster;
Envelope EnvChanOne;
Envelope EnvChanTwo;
Envelope EnvChanThree;
Envelope EnvChanFour;
Envelope EnvChanFive;
Envelope EnvChanSix;
//Filter Declarations
HPF      HiPassOne;
//Filter Configurations
1 => HiPassOne.Q;
//Instrument Declarations:
Clarinet Clari1;
Clarinet Clari2;
Saxofony Sax1;
//Instrument Configurations
.2 => Clari1.gain;
.2 => Clari2.gain;
.2 => Sax1.gain;
//Event Declarations
Event e1;
Event allFinished;
// Master Effects Patch
EnvMaster => dac;
// Channel Effects Patch
EnvChanOne      => EnvMaster;
EnvChanTwo      => EnvMaster;
EnvChanThree    => EnvMaster;
EnvChanFour     => EnvMaster;
EnvChanFive     => EnvMaster;
EnvChanSix      => EnvMaster;
//Instrument Patches
Clari1 => HiPassOne => EnvChanOne;
Clari2 =>              EnvChanTwo;
Sax1 =>   HiPassOne => EnvChanThree;
//Open Master Envelope
EnvMaster.keyOn();
// the notes
// MIDI note constants.
60 => int c;     72 => int C;
61 => int cs;    73 => int Cs;
62 => int d;     74 => int D;
63 => int ds;    75 => int Ds;
64 => int e;     76 => int E;
65 => int f;     77 => int F;
66 => int fs;    78 => int Fs;
67 => int g;     79 => int G;
68 => int gs;    80 => int Gs;
69 => int a;     81 => int A;
70 => int as;    82 => int As;
71 => int b;     83 => int B;
// We use musical tempo, and symbolic durations
240 => int tempo;
// integers 1,2,4,8 mean musical figures
dur duration[9];
240000::ms / ( 1 * tempo )  => duration[1]; // whole
240000::ms / ( 2 * tempo )  => duration[2]; // half
240000::ms / ( 4 * tempo )  => duration[4]; // quarter
240000::ms / ( 8 * tempo )  => duration[8]; // eighth
(duration[4] + duration[8]) => duration[5]; // dotted quarter
(duration[2] + duration[4]) => duration[3]; // dotted half
//1st part
[[E,2],[b,4],[C,4],[D,4],[E,8],
 [D,8],[C,4],[b,4],[a,2],[a,4],
 [C,4],[E,2],[D,4],[C,4],[b,3],
 [C,4],[D,2],[E,2],[C,2],[a,2],
 [a,1]
] @=> int v1a[][];
//second part
[[0,4],[D,2],[F,4],[A,2],[G,4],
 [F,4],[E,3],[C,4],[E,2],[D,4],
 [C,4],[b,2],[b,4],[C,4],[D,2],
 [E,2],[C,2],[a,2],[a,2]
] @=> int v2a[][];
// Play a fragment
fun void playVoice(StkInstrument m, int voice[][], int transpose)
    for( 0 => int i; i < voice.cap(); i++)
        if ( voice[i][0] > 0 )
            Std.mtof( voice[i][0] + transpose ) => m.freq;
            1.0 => m.noteOn;
        duration[voice[i][1]] => now;
        m.noteOff;
            1.0 => m.noteOn;
        m.noteOff;
fun void playv1()
    EnvChanOne.keyOn();
    playVoice(Clari1, v1a, 0);
    EnvChanOne.keyOff();
    EnvChanOne =< EnvMaster;
    e1.signal();
fun void playv2()
    EnvChanThree.keyOn();
    playVoice(Sax1, v2a, 0);
    EnvChanThree.keyOff();
    e1.signal();
fun void playv3()
    EnvChanOne.keyOn();
    e1.signal();
fun void playv4()
    EnvChanOne.keyOn();
    playVoice(Clari2, v2a, 0);
    allFinished.signal();
fun void SineWaveFilter(FilterBasic filter)
    float t;
    while( true )
        20 + Std.fabs(Math.sin(t)) * 5000 => filter.freq;
        .002 +=> t;
        10::ms => now;
spork ~ playv1();
spork ~ SineWaveFilter(HiPassOne);
e1 => now;
spork ~ playv2();
e1 => now;
spork ~ playv3();
e1 => now;
spork ~ playv4();
allFinished => now;
PostPosted: Mon May 10, 2010 6:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Since the noteOn() and noteOff() methods in StkInstruments shared the same kind of declaration, I think you need to call them in the same way:
Code:
1.0 => m.noteOn;
and
Code:
1.0 => m.noteOff;
You could also do the equivalent C-style calls:
Code:
 m.noteOn(1.0);
and
Code:
m.noteOff(1.0);
...possibly. I'm honestly not sure if ChucK has some way of dealing with a bracketless function name all by itself, not being assigned to. Worth a try anyway.
/Stefan
twist3d
PostPosted: Mon May 10, 2010 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
ahh brilliant. kinda feel a bit stupid for not adding that really, considering it's been used in that format for the note ons!
problem that has now appeared from changing that is the event "AllFinished" doesn't removed the shreds from the VM
many thanks for your help Stefan
