 Forum index » DIY Hardware and Software » Musical Interfaces
Squinth
Page 1 of 1 [4 Posts]
nobody
PostPosted: Mon Sep 27, 2010 12:37 pm    Post subject: Squinth
Subject description: The Squeeze Controller
I had an idea a few days ago for a "squeeze controller". It's basically a ball - or even a tube - that you hold in your hand and squeeze. Signals from hardness of squeeze, where you squeeze, and number of squeeze points are sent to a synth to produce sound.
Wondering how I can build it...
Audio files: 329
PostPosted: Mon Sep 27, 2010 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think Marije Baalman built something like that ... google could not help me in finding it though ... however she is a member here under the name of nescivi and she has a website too : http://www.nescivi.nl/
stolenfat
PostPosted: Wed Sep 29, 2010 11:04 am    Post subject: Reply with quote  Mark this post and the followings unread
this help?
http://www.tekscan.com/flexiforce/flexiforce.html
nobody
PostPosted: Wed Sep 29, 2010 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
That'll do! Very Happy
I could get four of these laid around the inside of a stiff foam tube and fill the inner space with some kind of rubber. All I'd need is to wire the leads through a CV-MIDI converter and then a MIDI cable and viola! Le Squinth!
