today> Twyndyllyngs Chez Mosc
Soviet VCO
Page 1 of 1 [13 Posts]
spitfire
PostPosted: Sun Feb 06, 2011 4:14 pm    Post subject: Soviet VCO Reply with quote  Mark this post and the followings unread
Hello,
I have a module from russian electronic organs "elektronika em-14", I think it's a waveform generator, or oscillator. But I'm not sure. Can you suggest me how to identify what kind of module is that, ant where to start searching for right pins to make it work. If I could find the place of power supply, it should work or not, then I only need to find waveform outputs and CV in...
few low resolution pics:
possible, not possible ?
sneakthief
PostPosted: Mon Feb 07, 2011 1:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I think it will be impossible to help you unless you take much sharper high-resolution pics in better light.
Sneak-Thief - raw electrofunk
spitfire
PostPosted: Mon Feb 07, 2011 6:21 am    Post subject: Reply with quote  Mark this post and the followings unread
you are right. i will scan them
spitfire
PostPosted: Wed Feb 09, 2011 1:03 am    Post subject: Reply with quote  Mark this post and the followings unread
So here's two modules. Smaller squere one I think is a filter or smth, and I think power supply must be connected to white/black/red wires. And the other one "oscilator.." i hope...
bubzy
Audio files: 64
PostPosted: Wed Feb 09, 2011 6:41 am    Post subject: Reply with quote  Mark this post and the followings unread
it might be worth trying to identify some of the chips and finding a pinout for them, that way you might be able to find the power rails. also could be worth checking the orientation of some of the electrolytic caps and working out the rails from there. certainly looks oldschool and possibly in need of a little resoldering (a few dodgy looking holes there). other than those basic ideas, i couldnt even begin to guess where to start. hope you find something useful on it.
metacohl
PostPosted: Wed Feb 09, 2011 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
A quick search on the chip numbers leads me to think the three center chips on the second board could be a DAC's and ROM's for a digital oscillator. Definitely not positive though. It' is still very hard to read the other chip numbers on the second board, though the 2nd set of pics are much better.
Also, I think the first board could possibly be a filter, it looks about right for a discrete filter to me. Though I could be totally off Confused
spitfire
PostPosted: Thu Feb 10, 2011 12:47 am    Post subject: Reply with quote  Mark this post and the followings unread
digital oscillator in this synth ? hmmm.
http://www.ruskeys.net/eng/base/electr14.php
sneakthief
PostPosted: Thu Feb 10, 2011 1:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the pdf for that SMD chip:
http://www.datasheets.org.uk/Scans/Scans-003/Scans-0077657.html
It's a Russian KA528BR2 (or KA528БP2 in Cyrillic) - I ocr'd it then translated it with google: it's a BBD chip! heh.
I bet it's part of a chorus unit.
unterbit
PostPosted: Sat Feb 12, 2011 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Its chorus+filter board.Yes its BBE chip.Our good BBD chip spitfire!
Hope you reanimate that,good luck! Is your X-4046 VCO working yet?i saw you done some etching&stuff.
spitfire
PostPosted: Sat Feb 12, 2011 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Smile I realized that my x-4046 vco pcb is not the right side. I made it as always mirror side, and it's not........ so i'm making a new one. will post if it will work.
cool people here. thanks
spitfire
PostPosted: Sun Feb 13, 2011 6:30 am    Post subject: Reply with quote  Mark this post and the followings unread
First I connected the "filter" board to power supply. I got 0,65volts from all blue outputs. I connected audio signal to one of them and pluged to amplifier the wires on the other side.. i got nothing. Am I doing stupid experiments ?
I also have this board... maybe thats an oscillator ? I found something about some chips, some of them were some kind of generators.
CHIPS: КР1012ГП2 КР1012ГП1 КР1012ГП3 2xК155АГ1 КР1012ИК2
Sebo
PostPosted: Sun Feb 13, 2011 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi:
May this can help you:
http://www.ruskeys.net/eng/base/ans.php
A lot of info, and some schematics of russian synth.
Sebo
My Music:
Strazdas
PostPosted: Sat Mar 19, 2011 5:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Sakiau, kad čia gera vieta konstruktoriams. Smile Laukiam garso.
-none-
