Anyone up for late night jams?
Page 1 of 1 [12 Posts]
Inventor
Audio files: 267
PostPosted: Wed May 11, 2011 4:33 pm    Post subject: Anyone up for late night jams?
Subject description: tonight for example...
Tonight or any other night, I'm thinking of doing some late night jamming. This wiil include a mix of ChucK music, vocals, and live coding. We can use Skype to bring in other's voices eventually as well. By late night, i mean after the regular programs end and on into the morning if we feel like it.
The jams will be done on the public channel for now.
If you are interested, come into the chat and say hi!
Les
(Inventor in chat)
Inventor
Audio files: 267
PostPosted: Thu May 12, 2011 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Audiodef and I jammed for an hour or so last night, then this morning I used a newly recoded version of the Late Night Jam Morpher program to remix the first five minutes of the recently released Code-11 EP. Here it is for your enjoyment.
Interestingly the circuitry to create something like this is not too extensive...
Les
Code-11 Remix 20110512 0852.mp3
Code-11 Remix
 Filename:  Code-11 Remix 20110512 0852.mp3
 Filesize:  5.25 MB
 Downloaded:  2155 Time(s)
PostPosted: Thu May 12, 2011 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Les
Thanks, Les and Audiodef. Enjoyed it, indeed!
Inventor
Audio files: 267
PostPosted: Thu May 12, 2011 5:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
You're very welcome kevin, and many more to follow... I'm getting into these jams and jammed twice today in the earlier hours. It's amazing what a little creativity will do for your inspiration (or is that the other way around?).
Les
So if you're reading this... chat, then jam!!!
nobody
PostPosted: Fri May 13, 2011 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool stuff, Les!
Here's our session from Wednesday.
http://audiodef.com/shows.php?show_id=9
Audio files: 232
PostPosted: Fri May 13, 2011 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
We know there are problems. We are 1/2 way through migrating to a new server. Have patience, don't go away, all will be better relatively soon.
Inventor
Audio files: 267
PostPosted: Sat May 14, 2011 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
The latest morpher i've written is sort of a guitar that's played by a song. It has 16 strings so it's a wide guitar, and each string is driven by a band-passed frequency bin. it sounds pretty cool and actually mimics the beat of the input song!
Les
Audio files: 301
PostPosted: Sat May 14, 2011 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yup, that one sounded nice!
It reminded of the speaking piano BTW. Basically the same idea, sample sound let it go through a set of bandpass filters and use the outputs to play the strings.
Inventor
Audio files: 267
PostPosted: Sat May 14, 2011 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep and thanks for your suggestions Jan, they quickly improved it a lot. It's funny, you work on something like that for hours and you get lost in the details but a second pair of ears can really help! Ears with a programmer's brain in between the to boot (and a musician's)...
OK, tonight I plan to, like as soon as I log in after typing this post, expand that same program to include both guitar and drums. I figure I can make a six-string guitar and a set of drums since Karplus Strong does both string synthesis and percussion. I'll try anyway, we will see how it goes...
Stop on by the chat if interested...
Les
Inventor
Audio files: 267
PostPosted: Sun May 15, 2011 12:02 am    Post subject: Reply with quote  Mark this post and the followings unread
So far tonight's big success was creating a feedback tamer, shown below in ChucK code:
Code:
adc => Gain feedback => Gain div => dac;
4 => div.op;
feedback => FullRect fwr => LPF lpf => Gain sum => div;
100 => lpf.freq;
Step bias => sum;
1 => bias.next;
while (true)
    <<<sum>>>;
    10::second => now;
With this code I can send music out the speakers and talk into the mic at the same time and not get any feedback wailing!
wow, that's nice because it opens up a whole holt of applications including the ability to inject sound into the feedback loop freely via guitar, bell,vlice, or whatever else is desired. The late night experimenting has paid off this time!
Les
nobody
PostPosted: Mon May 16, 2011 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Just reading this code makes me think I should learn ChucK. It doesn't look very hard.
Inventor
Audio files: 267
PostPosted: Mon May 16, 2011 7:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Chuck can be quite easy or as difficult as you like, depending on what you decide to do... so keep it simple and ChucK will be easy!
Les
