Akai S6000 for sale_.
vytear
PostPosted: Mon Jan 31, 2005 4:54 pm    Post subject: Akai S6000 for sale_. Reply with quote  Mark this post and the followings unread
Below are the stock specs. Mine also has:
16 total outs.
USB card
60 gig hard drive
128 extra ram
VOX64 upgrade
Manual
SKB 8 space rack with shelf.
• Sampling System: 16-bit linear
• Sampling Rates: 44.1kHz / 48kHz
• O/S Load: Flash ROM / Floppy Disk
• Disk Drive: 3.5 in. Floppy Disk
• LCD: Backlit 6 in. (320 x 240 dots graphics)
• Polyphony: 64 voices (expandable to 128 with optional VOX64)1
• Analog Audio Inputs: Front Panel: Left (Mono)/Right - 1/4 in. balanced jacks
• Rear Panel: Left (Mono)/Right - balanced XLRs (S6000 only)
• Analog Audio Outputs: Front Panel: Stereo headphone - 1/4 in. stereo phone jack (with level control)
• Rear Panel: 1/4 in. unbalanced jacks x 8 (expandable to 16 with optional IB-S508P)
• Digital Audio Inputs: Rear Panel: 1/4 in. phone jack x 1; Optical x 1
• Digital Audio Outputs: Rear Panel: 1/4 in. phone jack x 1; Optical x 1
• Connectors: MIDI: DIN 5P IN x 2, OUT x 2, THRU x 2
• SCSI: Half pitch 50-pin x 2
• Wordclock: BNC x 1
• Keyboard: PS2 type ASCII keyboard input x 1
• Memory: Standard Memory: 8 Megabytes (hardwired)
• Maximum Memory: 256 Megabytes
• Expansion Slots: SIMMS x 4
• APM: Assignable Program Modulation
• Filters: 26 Digital dynamic filter types with resonance
• Envelope Generators: 2 x ADSR with preset templates
• 1 Multi-stage EG with preset templates
• LFOs: 2 x Multi-wave LFOs
• Digital EQ: 3-band digital EQ with variable gain, frequency, Q per band
• Effects: SampleVerbII (EB20) 20-bit 4-Channel Multi-effects Processor1
• Hard Disk Recording: Yes
• Power Requirements: S6000: AC100-240V 50/60Hz 35W (60w max.)
• Dimensions: S6000: 482.6 W x 177 (179) H x 410 (466.7) D mm - EIA 4U
• Weight: S6000: 11.2kg / 24.6 lbs.
I am asking $1000 for the deal.
I have dumped way more into it than that.
feel free to e-mail with questions or to ask for pictures.
thanks_vytear
