X-Mux applications
davep
Audio files: 10
G2 patch files: 73
PostPosted: Sat Feb 12, 2005 2:41 pm    Post subject: X-Mux applications Reply with quote  Mark this post and the followings unread
Here are two patches that make use of the G2 X-Mux module. One uses it as a Tracking Generator, very similar to those found in the Oberheim Matrix6/12. The other uses it in a similar way, but substitutes an audio signal for the control signal, creating a lo-fi waveshaper. It's too bad the module won't run at "red cable" rates when you patch an audio signal into it, but it may be useful as an odd distortion effect.
Use the set of eight Constant knobs to mess with the signals. Check out the variations for examples.
X-MUX as Tracking Generator.pch2
X-MUX module used as a Tracking Generator
 Filename:  X-MUX as Tracking Generator.pch2
 Filesize:  1.78 KB
 Downloaded:  1572 Time(s)
X-MUX as Waveshaper.pch2
X-Mux module used as a lo-fi waveshaper.
 Filename:  X-MUX as Waveshaper.pch2
 Filesize:  1.94 KB
 Downloaded:  1636 Time(s)
Dave Peck
