 Forum index » DIY Hardware and Software » Video synthesis and manipulation
a cmos video Synth
Page 1 of 2 [43 Posts]
Psyingo
PostPosted: Sun Apr 29, 2012 5:41 pm    Post subject:  a cmos video Synth
Subject description: progress reports.
After building my modular drum machine, i started getting into video synthesis. I decided i would do the 25 random cmos challenge again, except this time i would make a video Synth. So i have started down this path. it was difficult at first but now that i have the sync generator working it's very fun.
I am using vga since it is an analog standard. Vga has each color channel on a septate pin. I plan on making a color mixer to split a signal into the different color channels. Lots of stuff to do...
Here's the good stuff, pics!
That's just some of the pictures i took.
I will update my progress here.
UPDATE 2/05/2012:
I have decided for my first foray into video synths that I wouldn't limit myself to the CMOS challenge. So I will be using any chips I see fit. I will still be using CMOS as I think the patterns that can be created with them look good, but i think there are some other things that I need that I dont have available in my 25 random cmos pack i got.
I have a decent working VGA sync generator on a breadboard, i will need to solder it up onto a board. I also need to get a pixel clock working. the pixel clock for 640x480 is about 25mhz, which is quite high and i believe out of the range of the 4000 cmos. i will probably working with a much lower clock, perhaps 1.5625mhz or so.
anyways... more to come.
sonic
PostPosted: Mon Apr 30, 2012 5:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Intriguing stuff Psy. It'll be interesting to see where this goes.
corex
PostPosted: Mon Apr 30, 2012 9:31 am    Post subject: Reply with quote  Mark this post and the followings unread
That's really nifty. Interested in seeing some schematics as you go!
PostPosted: Mon Apr 30, 2012 10:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool stuff... I'm definitely going to follow your progress... any schematics you're willing to share along the way would be welcome. Video is tougher than audio... almost anything can make sounds, but with video, if you don't have sync, you have nothing [stating the obvious for anyone who's delved into such matters].
Psyingo
PostPosted: Mon Apr 30, 2012 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, exactly. analog video synthesis seems to be a rather rare art now, not very documented. the lzx and dave jones stuff is commercially available, but there isnt much out there as far as information goes for the DIY'er.
video is a heck of a lot tougher, especially if you have specific results in mind.
i think audio people don't know how easy they have it Wink
sync is certainly is a big hurdle to overcome, and without it you wont get much but a bunch of scrolling lines. fortunately for me, i got my sync generator working yesterday so i was able to generate solid frames.
now comes the process of building mhz oscillators with sync and all the other fast clocked logic.
PostPosted: Mon Apr 30, 2012 4:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Kinda straying from the Lunetta topic, but I made a video effects box which perhaps only slightly qualifies as doing synthesis, and it dealt with sync in a rather simple manner. No sync generator.
Basically, I split a composite video signal, sliced it up using a comparator which clocked a 4040 divider, then added a few of the divisions back to the original signal. Since the original signal is still there, the sync is preserved. Limited, but some fun stuff for such a dumb circuit.
I called it the Vidiffektor: http://www.jamesschidlowsky.ca/electronics.html#vidiffektor . There be a link to a demo video that shows pretty much what it does.
Edit: updated dead link.
-minus-
PostPosted: Tue May 01, 2012 11:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Some nice photos there! I like the third one. Can the patterns be controlled by audio or is it kind of a stand alone thing?
I was watching the video RingMad linked to as well and was thinking about whether stuff like that and your patterns can be mixed on the same screen.
Nice to see some visual experimentation. Good to explore a different area than the usual blip bleep stuff.
corex
PostPosted: Tue May 01, 2012 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's a pretty interesting affect and the simplicity of the approach is interesting -- can you please describe the circuit more thoroughly (or post a schematic Very Happy )?
jnuaury
Audio files: 9
PostPosted: Tue May 01, 2012 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
I also have a CMOS video synth I built a few years ago
http://vimeo.com/31933034
az/gde
Flickr
YouTube
Psyingo
PostPosted: Tue May 01, 2012 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can you divulge any details? Myself and others in this thread I'm sure would love that.
Psyingo
PostPosted: Wed May 02, 2012 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
updated the original post.
jean bender
PostPosted: Sun May 06, 2012 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Hy Psyingo !!
Great work again !!
Could you give us some informations about your vga sync ? It would be great, cause i've never been able to build it, except using arduino, and i'd like to know how to build it without these kind of stuff...
THanks !!
http://h.a.k.free.fr/
www.electroncanon.org
Psyingo
PostPosted: Mon May 28, 2012 2:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
here are some stills ive taken over the past few weeks working on the video synth.
http://imgur.com/a/JW90C
and the most recent one...
i may share a schematic for one of the modules in the next couple of days once i finalize the design...
-minus-
PostPosted: Mon May 28, 2012 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some nice photo's there! This is interesting research you are doing. I'm enjoying seeing this develop. I'd like to do something like this myself! It seems like a major project to me. I'm still trying to get a basic logic synth finished! Laughing In many ways this is the Holy Grail of 'Lunetta's'
jean bender
PostPosted: Mon May 28, 2012 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow !! That's totally amazing !! I've taken a look about the way to interface my lunettas modules with vgas and tvs.. but i haven't found yet the way to have such beautifuls images ( and my best results was to send audio paths into tvs... mmm).
I really wonder how your sync is built, and i just can say BRAVO, it's so great !
thanks for letting us dreaming a bit more.. and giving the envy to go further !
Exclamation Very Happy Exclamation
PostPosted: Mon May 28, 2012 4:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, this image really looks like what I would imagine Lunetta sounds would look like. Impressive work.
And it looks like I totally forgot to post a schematic of my Vidiffektor as requested, although I don't want to dilute this topic with non-Lunetta stuff, and I thought my description of it was pretty detailed. Anyway, I'll dig it out and clean it up....
James.
DGTom
PostPosted: Mon May 28, 2012 5:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some amazing stills there Psyingo!
Would love to see what you are using for sync, most of the things I've tried have been hit & miss or the aforementioned arduino / micro solutions, or this;
http://www.pyroelectro.com/projects/masochists_video_card/index.html
which is a monster!
looks like you have a really lovely stable image & really broad range of stuff coming out (on a couple of differant monitors?) I really like the layered, textural stuff like this one;
http://i.imgur.com/5Vaxjh.jpg
Psyingo
PostPosted: Mon May 28, 2012 7:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually the sync im using is a lot more fast and loose than the masochists idea. I'm only using a few 4040's (granted that does take the place of 6 4-bit counters) and some inverting buffers. im not using a vast series of logic gates to derive the pulses such as with the masochists. luckily vga is a pretty forgiving standard!
the sync circuit also has ramp generators, blanking and output buffers.
yes, i've been using a few different monitors to test my outputs, one is an lcd tv using the composite input, the other is an oldschool commodore 64 monitor using composite, a sony television using composite, and an ibm vga monitor... the vga by far looks the best, very crisp sharp images! the composite converter introduces a lot of noise into the signal, but it adds a certain grit which is nice in some cases.
i will soon be adding a composite input to the set up so i can process cameras and other input signals. seperate the colors, delay the colors, blur them, etc.
i am deriving a lot of my inspiration from the ems spectre/spectron which i have acquired some diagrams of. unfortunately i cannot share them though. it is a very complex system compared to mine (so far. >Very Happy)
DGTom
PostPosted: Mon May 28, 2012 8:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I might have to give VGA a go, I've mostly been playing around with composite & getting syns that works on more than one TV / Monitor has been elusive, are you using a crystal to generate the clock?
droffset
PostPosted: Tue May 29, 2012 2:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice psyingo, I think I have a couple of chips that generate horizontal synch of some nature, I'll try to dig them out and post info on it.
Edit: Spelling mistakes.
inlifeindeath
PostPosted: Wed May 30, 2012 4:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'm really trying to wrap my head around this video nonsense, but I just perfboarded the circuit below and was wondering what kind of input you all could give me to use this to get a signal i can manipulate with my lunetta.
The schematic is just the sync circuit from a pong schematic i found.
Video CMOS schem.pdf
 Filename:  Video CMOS schem.pdf
 Filesize:  18.26 KB
 Downloaded:  1346 Time(s)
Psyingo
PostPosted: Thu May 31, 2012 1:19 am    Post subject: Reply with quote  Mark this post and the followings unread
where are the sync pulses coming from in that circuit?
inlifeindeath
PostPosted: Thu May 31, 2012 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the reply!
I was going to experiment just feeding in oscillators from my lunetta, but i know you had said you need a really fast clock, so I drew up a crystal oscillator schematic with a divider.
do you think the 40106 oscillators or the crystal will work (i have some 20mhz ones)? What else would you suggest I build to get something out? Also, how does the video input work?
Video CMOS clock and divider.pdf
 Filename:  Video CMOS clock and divider.pdf
 Filesize:  14.18 KB
 Downloaded:  860 Time(s)
Psyingo
PostPosted: Thu May 31, 2012 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
is this pong schematic you got ntsc or pal?
you should look up the timing signals for h and v sync of ntsc and pal. H and V sync need to be rather stable or you will get scrolling. also unless you get a color encoder chip or manage to make your own color encoder you will only get a b/w signal.
take a look at this, it has some important frequency information. http://www.epanorama.net/documents/video/video_timing.html
i dont think you will get much if you just feed whatever signals into the h and v sync. you need proper timing signals to get a good image. you might get some warbly lines, but it will get boring fast when you can't generate proper shapes and patterns.
Psyingo
here is a short video of some repeating patterns with a voltage controlled differentiator
