Mac OSX Editor, MOTU MIDI Express 128, Micromodular Problem
Page 1 of 1 [7 Posts]
GovernorSilver
PostPosted: Thu Mar 10, 2005 9:07 pm    Post subject: Mac OSX Editor, MOTU MIDI Express 128, Micromodular Problem Reply with quote  Mark this post and the followings unread
Once upon a time, I got the OSX version of the Editor to work with this setup.
Now that I'm back from vacation, I can't get the Editor to find my Micromodular anymore. No matter what ports on the MOTU that I connect the PC In/Out ports, the Editor always says "Looking" or "Still Looking".
I hit "rescan MIDI" in Audio MIDI Setup and it didn't report any problems. Since neither the Editor nor Audio MIDI Setup are well-documented for use in OSX, I am a loss at what to do.
johntennant
PostPosted: Mon Apr 25, 2005 2:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Did you update OSX at all? I'm having the same issue. Once it worked, but now it doesn't and the only thing I can think of that changed was an OS update. What do you think?
-J
thapoke
G2 patch files: 5
PostPosted: Fri Feb 24, 2006 6:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
Ive been experiencing the same problem using a midiman 2x2 interface.
Ive got it working now by using my roland pc 300 interface for the 'out' port and the midisport for the 'in' port, so I imagine its some sort of problem with the midi interfaces, osx and the drivers?
PostPosted: Fri Feb 24, 2006 7:00 am    Post subject: Reply with quote  Mark this post and the followings unread
I am still using an older mac for the OS9 editor for the NM-1. It runs fine with the midisport most of the time .. but a few times the midisport driver has died and I have had to reinstall it. I have it running great on the same box with OS X too, but the midisport driver seems to be a little flaky at times.
Most M-Audio driver software seems to dislike being reinstalled on top of another driver, so I always deinstall the dead stuff before I reinstall. It is also a good idea to remove all M-Audio drivers you are actually not using.
Flickr
GovernorSilver
PostPosted: Wed Mar 08, 2006 9:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
It took me a while, but I solved my problem! A huge part of the delay was I focused heavily on acoustic instrument playing and neglected my musical electronics.
The problem was that I forgot that the MOTU Midi Express 128 is incapable of mapping MIDI without a computer attached. It needs Performer or some other MIDI application that will tell the MOTU what input port goes to what output port. I used Max/MSP to do this. Embarassed
Another problem was one of the MIDI cables which came in a pair (which I bought so I could use the Editor of course) was a bad cable! I found this out later when I was trying to get my keyboard to trigger notes on the Micromodular. After scratching my head, cursing, etc. I got the bright idea to try a different MIDI cable. Guess what, it worked with the different cable! Embarassed
Next step: See if I can get the MOTU to broadcast my keyboard MIDI output to both my XL7 and Micromodular at the same time.
Lesson Learned: Check my damn MIDI cable next time something goes wrong with MIDI. Laughing
computerdisco
PostPosted: Wed Jun 07, 2006 4:25 pm    Post subject: Nord Micro Getting me down Reply with quote  Mark this post and the followings unread
Hello all, been reading this thread (and a few more) and been enjoying it muchly.
I have a problem with a Micro Modular I bought off ebay.
I'm using Mac with OSX 10.3 or 10.46 (dependent on which I boot off)
And my Midi is through my novation X25 keybard.
after the editor software loads it brings up a message saying.
Synth exception.
Error in synth..
Open the MIDI dialog and enable the port again.
When I do it looks for the micro again, finds it says V3.03
and brings up the error again..
Any suggestions?
computerdisco
PostPosted: Thu Jun 08, 2006 12:54 pm    Post subject:  Sorted
Subject description: Ha found the problem!
It was my Novation x-25 all the time. I got a edirol U20 back of a friend i gave it to and its all smiles and woof crack noises.
Ta!
