How te get the OS version a patch was made with
Audio files: 309
PostPosted: Sat Mar 19, 2005 4:44 am    Post subject: How te get the OS version a patch was made with Reply with quote  Mark this post and the followings unread
When you open a G2 patch or performance into a text editor (like Word, WordPad or Notepad on windows) the first four lines will show something like :
Version=Nord Modular G2 File Format 1
Type=Patch
Version=22
Info=BUILD 224
The last line gives the build version of the OS the patch was saved with.
When you are in the editor you can see it's build number by going through menu/help to open the about box.
iAnother interesting number is the Version number, 22 in this case. This should be a measure for patch compatibility.
It's a bit less straight forward to check that number, you'll have to make some patch with your editor, save that patch next open it in a text editor to see what version your OS generated.
In general though earlier patches by build number will open in later OSes (but sometimes the DSP percentage goes over 100).
Sometimes later patches will not open at all in earlier OSes.
Jan.
