fishfude
Posted: Mon Jan 06, 2014 1:24 pm Post subject:
Low Pass Resonant Filter Question Subject description: Why the 470k resistor across the 500k resonance pot |
Hiya folks,
So I was building the resonant low pass filter section from the weird sound generator and I was deeply curious as to the effect of having the 470k (R35) resistor across legs 1 & 3 of the 500k resonant filter (R32), as opposed to just using a pot of half the value? (See image)
Also, I decided to just go with a 220k pot instead and it didnt seem to work, it just introduced noise when opened.
Finally, I decided not to connect leg 2 to leg 3 on any of the pots (they are acting as series resistors so I dont have to right?) and very interestingly, when I touch my finger between legs 2 and 3 of the pots I get oscillations and sonic textures. Anybody able to explain this?
ff |
Mongo1
Posted: Wed Jan 08, 2014 8:11 pm Post subject:
| Quote: | | as opposed to just using a pot of half the value? |
If it were two pots paralleled together, using a pot of half the value would work. When you put a fixed resistor in parallel with a pot, it gives it a different response curve.
I'd suggest using a simple spreadsheet, and put 10 different settings of the pot in it. You'll be able to see the difference...
Gary |
fishfude
Posted: Thu Jan 09, 2014 4:17 am Post subject:
Hi Gary,
Thanks for that. I managed to find out some more information on it from GEOFEX and other sources.
So, yeah, it's creating a reverse log curve for the pot with a max at ~50% the pot value. |
