ZooBooBooZoo
Posted: Mon May 05, 2014 5:01 am Post subject:
Need Help In Creating & Finalizing A Glitch FX |
Hi all,
I followed this tutorial:
https://www.youtube.com/watch?v=spbsxC4ow5M
And then added a few things of my own, and ended up with:
http://s21.postimg.org/63y7qsax3/Untitled2.png
Basically it works quite well except:
1) The main issue: I have set a few midi notes to glitch at different rates like in the tutorial. The problem is that if I have adjacent notes which are right next to each other(legato) than the glitch rate would change but the bit of audio being glitched is the bit audio of the previous note.
So for example if I have(this supposed to be a timeline with 1/4 grid):
Code: |
Kick----------->Snare------------>Kick----------->Snare------------>
C(1/32 rate)--->C#(1/64 rate)---->C(1/32 rate)--->C#(1/64 rate)----> |
When the C# is played the FX process the Glitched Kick instead of the Unglitched-Just-Yet Snare. so the way I see it is since the notes are played one right after the other the gate stays at "1"/On and is not retriggered and thus the FX doesn't sample the current audio being played.
I need to know how to make the gate retrigger even if the notes play one right after another
Maybe I can get the midi note length somehow and use it to turn the gate to zero just before it ends? is there a simpler way or some gate module with re-triggering capability that I missed?
2) I tried implementing an attack functionality like this:
but the result was not so good... it sounded a lil "weird" and high pitched in some attack settings...
Any suggestions?
Thx, ZBBZ. _________________ PC:
CPU: i5 3470
M-Board: Gigabyte H77
RAM: 2X4GB DDR 3 1600
Graphics: Intel Graphics HD 2500
Hard Drives: Western Digital: 1TB Black(WD1002FAEX), 500GB Green(WD5000AACS), 160GB(WD1600ADFD)
OS: Windows 7 Ultimate 64 Bit
Sotware:
Sonar X2, Native Instruments Komplete, Additional VSTs...
Audio Hardware:
External Audio Interface: PreSonus FireBox
Mics: Shure SM57 & KSM27
Insturments:
Casio CD-120 Digital Piano
Guitars: Ibanez Classical, Martin DC-1, Jackson Kelly, D'Angelico Excel |
