Posted: Sat May 31, 2014 2:45 pm Post subject:
magnetic stirrer |
a CPU fan, a HDD magnet and a PWM controller circuit from here (with some different values).
The fan is mounted on a thin piece of wood, slightly smaller then the box, which is attached using some double sided adhesive foamtape to reduce
vibrations. I tried to get everything centered but it was pretty hard to get the magnet right because of it's shape. It's not too bad though, it doesn't
'walk away' and at low speeds it works great. I riveted some clear plastic to the top of the box as protection.
Description: |
Filesize: |
61.34 KB |
Viewed: |
620 Time(s) |
Description: |
Filesize: |
54.67 KB |
Viewed: |
580 Time(s) |
Description: |
Filesize: |
69.52 KB |
Viewed: |
562 Time(s) |
Joined: Apr 03, 2004 Posts: 24476 Location: The Netherlands, Enschede
Posted: Sat May 31, 2014 4:12 pm Post subject:
Nice!
Hope it doesnt make too much noise? _________________ Jan
Posted: Sat May 31, 2014 4:48 pm Post subject:
As long as I don't turn up the speed very high it doesn't make much noise.
And the noise is coming from the stirbar, which is a decapitated nail right now, grinding on the glass.
I don't really have a good mic to record it but I was thinking that if I add a reed switch I should be able
to use it as an oscillator  _________________ "My perf, it's full of holes!"
analog_backlash
Joined: Sep 04, 2012 Posts: 393 Location: Aldershot, UK
Audio files: 21
Joined: Dec 11, 2010 Posts: 1007 Location: Toronto, Ontario - Canada
Posted: Mon Jun 02, 2014 11:37 am Post subject:
You can get bioluminesent algae that glows when the water moves. No led's required and the glow will last for a long time (glow sticks only last for a few hours). |
analog_backlash
Audio files: 21
Posted: Mon Jun 02, 2014 4:15 pm Post subject:
Cynosure wrote: | You can get bioluminesent algae that glows when the water moves. No led's required and the glow will last for a long time (glow sticks only last for a few hours). |
True and it's a 'greener' alternative (as long as you don't resort to grow lights) but you can wear them out and they stop glowing (albeit temporarily). Your right about the glow sticks - once the chemicals are exhausted they stop glowing.
Don't know what the algae rights people will think about it . |
Joined: Jan 07, 2009 Posts: 1220 Location: Scottish Borders
Posted: Tue Jun 03, 2014 9:55 am Post subject:
cool phobos , , now , how about warm ferric chloride for some speed etching heheheh , hmmmm , it would probably strip it bare including the resist areas
Dave. |
Posted: Tue Jun 03, 2014 10:05 am Post subject:
Joined: Jan 15, 2011 Posts: 428 Location: Montreal, Canada
Posted: Mon Jan 05, 2015 1:12 pm Post subject:
PHOBoS wrote: | I was thinking that if I add a reed switch I should be able
to use it as an oscillator  |
Magnetic oscillator sounds like a cool idea! A stiroscillator!
-- James |
