Posted: Sun Aug 31, 2014 3:50 pm Post subject:
Circle to Square converter Subject description: using an old motor as a rotary controller |
I disassembled an old printer and one thing that came out of it was a big motor. After removing the controller board
I wondered if there was some more circuitry inside because there was clearly another PCB under the 'platter'.
So I removed it and found a PCB trace coil which looks like a circular squarewave. Curious if it would produce
a useful signal I hooked up my scope and saw that it gave a nice (audible) sinewave with an amplitude of ±20mV
The first thing I did was amplify it to a max level of about 5Vpp using some opamps. The TL071 is used because
of it's high input impedance, the LM358 because it goes pretty much to GND and I wanted the output voltage to go
between 0 - 5 V. Of course the amplitude varies depending on how fast you rotate it.
Next I turned the sinewave into a square. I tried using a CD40106 first but that didn't work to well.
The CD4069UB works great, the more gates you put in series, the more the signal resembles a square wave.
But I still added some schmitt trigger inverters to square it up some more. I also used the signal to indicate
if the platter is moving or not by charging a capacitor when it moves. Initially I used a CD4040 to divide
the squarewave which got reset when the platter is idle.
So I soldered the circuit onto some perf, made a frontpanel for the connectors, a simple wooden case
and it all worked well.
However there was something I was wondering about,..
On the other side of the PCB (with the coil trace) there are 6 coils, divided in 3 pairs that are hooked up in parallel,
that together with the magnet on the platter make up the actual motor. So, could I use these to indicate the direction
the platter is spinning ? (and use a CD4029 instead of a CD4040)
I hooked up my scope again and also got a sinewave from those coils but with a larger amplitude (frequency is lower though).
So the 3 coil sets produce 3 sinewaves that are out of phase, which resembles the waveform of a rotary encoder.
Now I already had the idea that it should be possible to use some flipflop's to convert the signal of a rotary encoder into
a direction output but wasn't sure how yet. I found the answer online and as it turns out it only takes 1 D-type flipflop
to do this.
So I used 2 coil sets for a quadrature waveform and made use of the CD4069UB again to square up the signals.
Because the amplitude is already much higher (4Vpp max) I didn't need an extra opamp this time.
The flip flop then gives the directional information which controls the up/down input of a CD4029.
So I had to do a bit of resoldering and add another PCB and then there was one small problem. I already made
the panel and now had another output (direction) which i wanted to add. Originally I had two outputs that gave
the status of the platter: 'rotating' or ' idle', so I sacrificed the 'rotating' output and used it for the directional output instead.
And just in case it's not clear, it does not spin by itself, but it is used as a manual generator
Description: |
not drawn in the schematic is the 9V voltage regulator |
Filesize: |
77.13 KB |
Viewed: |
816 Time(s) |
Description: |
Circle to Square converter |
Filesize: |
51.88 KB |
Viewed: |
728 Time(s) |
Description: |
Filesize: |
55.8 KB |
Viewed: |
747 Time(s) |
Description: |
Circle to Square converter - coil trace |
Filesize: |
59.52 KB |
Viewed: |
704 Time(s) |
Joined: Jan 15, 2011 Posts: 428 Location: Montreal, Canada
DUBmatze
Joined: Feb 18, 2013 Posts: 150 Location: south Germaica (schwabilon)
Posted: Mon Sep 01, 2014 6:40 am Post subject:
hehe, thats cool!!!
you can scratch your Lunetta/ modular now ..... (i use a custom cut single side record for scratching with square and sine waves... but there is no direction out ... )
I think the sine out is cool on very big soundsystems with big subwoofers or scoops wile making some bass sweeps. (but watch your beer and your stomach at 5kw+ ) |
Joined: Jan 07, 2009 Posts: 1220 Location: Scottish Borders
Posted: Thu Sep 11, 2014 10:31 am Post subject:
Nice work , Phobos , I was just thinking (an electric high speed drill with a rubber wheel in the chuck, touching the disc)  |
