About Power connection
Page 1 of 1 [5 Posts]
pepechispa
PostPosted: Mon Nov 10, 2014 9:16 pm    Post subject:  About Power connection Reply with quote  Mark this post and the followings unread
Hello, my question is perhaps silla. But in the PCB, for example the ARP filter, which has no drills for soldering the eurorack Power socket, do you solder directly the wires of the ribbon cable paired +12 0 -12? Use an adaptar? Perhaps is very easy but I don't see it
gdavis
PostPosted: Tue Nov 11, 2014 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some of the layouts have been updated for different connectors. An adapter is good for an existing board. It's also easy to modify the layout. For the ARP filter I just whipped this up in MS Paint so it's a little sloppy but should work. Double check the spacing for the connector to make sure there's room, might need to scooch things around a little.
 Filesize:  68.74 KB
 Viewed:  462 Time(s)
pepechispa
PostPosted: Tue Nov 11, 2014 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot Gdavies. I William go for the once and tell how was. Thanks
pepechispa
PostPosted: Tue Nov 11, 2014 7:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I see only one track to ground in other designs i.e steiner-parker filter 3 tracks to ground. 3 better than one as my los electronics teacher used to say me?
Snaper
PostPosted: Wed Dec 03, 2014 2:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Any vector graphic soft could open and modify it.
I've used Inkscape, and changed the MT power header to standard EURO in all of my builds.
