wavefreaker on +-15V
Page 1 of 1 [5 Posts]
AlasdairMoons
PostPosted: Mon Dec 01, 2014 1:33 pm    Post subject: wavefreaker on +-15V Reply with quote  Mark this post and the followings unread
Does the wavefreaker run on +-15V as is or do I have to change some Resistors like R4 R6 and R18??
my Music-Channel:
my Facebook:
Audio files: 161
PostPosted: Tue Dec 02, 2014 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Sascha.
My wave freaker runs on the usual +/- 12V , there is something in the description text on the mfos web page for the pcb , it says the unit must be powered from a minimum of +/- 12V , im not sure what would need changed for 15 V operation.
AlasdairMoons
PostPosted: Tue Dec 02, 2014 12:53 pm    Post subject:   Reply with quote  Mark this post and the followings unread
I'm not shure .. cause I'm not an electronic-nerd Very Happy
the Zener Diode Z1 (zener 10V) and the zener Z2 and Z3 look like a voltage regulator to U2 and U3
But I'm not shure if the resistors R4 R6 and R18 need to be changes to get the desired voltage output ....
my Music-Channel:
my Facebook:
roglok
PostPosted: Sun Jan 11, 2015 6:22 am    Post subject: Reply with quote  Mark this post and the followings unread
those resistors are current limiters to prevent excessive current flow through the zener. there's no need to change them for 15V operation.
more on zener voltage regulators:
www.electronics-tutorials.ws/diode/diode_7.html
bassculture
PostPosted: Sun Jan 01, 2017 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello !
Currently building a Wave freaker Wink
And it is supposed to be installed in a 5U / +/-15V Powered rack (with dotcom & MOTM modules...)
Did you had any troubles running yours @ 15V ?
