today> Various Artists March Equinox concert
 Forum index » Instruments and Equipment » iOS - iPad/Phone/Pod etc
Post Update Blues
Post new topic   Reply to topic Moderators: mosc, v-un-v
Page 1 of 1 [2 Posts]
sacchinchump
PostPosted: Fri Apr 03, 2015 4:15 pm    Post subject:  Post Update Blues
Subject description: iOS 8.2 Issues iPad Mini
I'm baffled. Halp!
I don't have any other place to ask and you guys seam to be a knowledgeable group.
I use my iPhone 5 and iPad mini with Amplitube and other apps to process sound via a iRig. My issue in both devices is none of the apps will select the headphone input where the iRig is plugged in. I can hear apps playing through the iRig, like a synth app, but nothing that is plugged into the iRig and then out back to my mixer.
I thought maybe I broke my iRig and bought the Griffin cable that's basically the same thing as the iRig. Same issue!
I've updated all software and apps. Cleaned the headphone jacks. Still nothing works.
I even installed AudioBus because I thought maybe the new interapp audio thing wasn't working. Still all I can select as an input in AudioBus is the internal device mic.
I'm usually pretty good at figuring this stuff out but I'm lost on this one. Searching Google is a bit difficult since once you type in iOS/audio bugs you mostly get other issues. I looked through the iRig site and they are up to date with 8.2 as well as AudioBus and all the others.
-Annoyed with Apple
DES
PostPosted: Fri Apr 03, 2015 10:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Did you try rebooting? In the past this has helped me with some apps not working. Make sure the reboot is the one were it shows you a slider to turn off the iUnit, then power it back up.
www.davesneed.com
