 Forum index » Online Music
Paranoid Jitter
Page 1 of 1 [2 Posts]
PostPosted: Tue Jun 02, 2015 11:14 pm    Post subject: Paranoid Jitter Reply with quote  Mark this post and the followings unread
This is probably the first recording I've done that I'm really happy with. I had three delays going in this one -- the loud, horn-like voice was going through the 1776 Multiplex tape emulator, the odd liquid bubbling up sound was through the Mad Bean Cave Dweller 2nd Ed (Dub) delay, and the rapid, repetitive beat was through the Synthrotek Echo, just a very slight touch with this voice. (The beat also got a bit of passive filtering from the FC Electro VCF.)
I had a lot of fun playing with the Bit switches in the Klee with this one, and changing the sliders as the sequencer was playing that note. I keep learning more and more things you can do with this AMAZING module!
I also learnt you can run the Yusynth Clock Divider back into itself -- I had it dividing the fast clock (that was driving the beat at 1/1) by 8 and then 3, so it was working out to 1/24, if my reckoning is right.
The "envelope" for the horn-like voice was just the Klee's Master Clock Out driving the Position CV on the Orgone Accumulator, shifting it from the horn-like waveform to a silent one on another position. It then went through the RS-20 filter to remove SOME of the high-end.
2015-6-3 paranoid jitter.mp3
 Filename:  2015-6-3 paranoid jitter.mp3
 Filesize:  11.84 MB
 Downloaded:  3383 Time(s)
PostPosted: Tue Jun 09, 2015 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Some nice sounds there :-)
