reeldark
Posted: Fri May 20, 2005 12:57 pm Post subject:
how can i seperate Variable midi button signals in max? |
Hey all, probably a simple answer to what im about to ask.
What im trying to do is connect a midi keyboards variable buttons to max so to control a slider bar that of course effects a parameter, being volume, pitch, note etc. Ive found that using "midi in" allows this but the problem im having is that i wish to seperate each button to seperate sliders. ive been trying to use "select" and "route" to do this but even though "select" does only respond to the channel i set it to it will only send a signal when the controller releases the value of the set number and hence, is no longer variable.
Does anybody know of another way to do this am i completely on the wrong path? please help. |
diskonext
Posted: Sat May 21, 2005 8:07 am Post subject:
I don't understand the question, exactly.
Do you want to build a MIDI auto-learn functionality? Or do you have a problem selecting specific CC numbers out of the MIDI stream?
-diskonext _________________ :wq |
reeldark
Posted: Sat May 21, 2005 2:11 pm Post subject:
I have a problem selecting specific CC numbers out of the MI |
Thnx for your prompt reply,
I have a problem selecting specific CC numbers out of the MIDI stream,
i basically want each dial button on the keyboard to affect a different slider.
I have 4 dials on the keyboard that send a signal on channels 10,11,12,13, each with a value from 0-127, from "midiin" ive told "select" to seperate and send signals from only these channels, however, its output is now a bang for each number from 0-127 and not the initial integer.
i want the initial integer to adjust a slider but obviously the slider doesnt understand bang to accumulate or subtract the value when the dial is turned.
I look forward to your reply, thanks again. |
diskonext
Posted: Sun May 22, 2005 4:32 am Post subject:
Heya,
here's a picture of how I normally do these things in Max.
Because "route" routes on the basis of the first number, the output from the first two "ctlin" outputs (value and CC#) need to be "swap"ed, then "pack"ed so they can be "route"d according to CC number. The 10/11/12/13 in the route object are just imaginary CC numbers, fill in the proper ones for your setup.
BTW, I haven't tested whether this will actually work, I do think so, though
-diskonext
PS. I might be completely mistaken here, I do assume you meant CC where you wrote channel? _________________ :wq |
reeldark
Posted: Sun May 22, 2005 5:41 am Post subject:
Thnanks |
Your a star thanks a lot, ill give it a try when i get into uni on monday & let u know how i get on, thanks again,
Keep it reel, www.reeldark.co.uk  |
