 Forum index » DIY Hardware and Software » The Repair Shop
Emu vintage keys sound module repair
Page 1 of 1 [2 Posts]
9 volts
PostPosted: Mon Dec 28, 2015 12:41 am    Post subject: Emu vintage keys sound module repair
Subject description: Dead
Hi there, I turned on my emu vintage keys yesterday and while using it, it crashed. When I restarted the LCD screen was just black blocks and no LEDs turn on. The relay doesn't click either. I assumed this was a power supply issue and tested the unit with another power supply and unfortunately got the same results. There doesn't seem to be a schematic or service manual available. Has anyone worked on one of these or had a similar problem? Thanks
Dan Lavin
Audio files: 21
PostPosted: Fri Jan 01, 2016 10:01 am    Post subject: Reply with quote  Mark this post and the followings unread
9 volts, I think you probably are correct with your assessment: probably the power supply. Emu's share common hardware between units and are based on their Proteus line. Here's a link to Proteus power supply repair that I did a few years ago. This is the first generation Proteus line, but the basic principles should apply.
http://electro-music.com/forum/viewtopic.php?highlight=proteus&t=25815
Good luck!
Synth DIY since 1977!
