Wren in Linux with Wine (save to disk problem)
Page 1 of 1 [11 Posts]
Wobble
PostPosted: Sun Feb 12, 2017 5:53 pm    Post subject: Wren in Linux with Wine (save to disk problem)
Subject description: need support
I convinced my friend to use Wren.
However using it in Linux with Wine, when he saves to disk the file size seems about right, but there is only 1 second of sound in it, even if he saves 2 minutes.
Anyone know solution?
Audio files: 326
PostPosted: Mon Feb 13, 2017 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Could you post such a wav file here with an estimate of how long it should be (music wise), I'll have a look at it then.
Wobble
PostPosted: Mon Feb 13, 2017 8:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Attached is an output.
low.wav
Exported from wren in wine.
 Filename:  low.wav
 Filesize:  110.04 KB
 Downloaded:  975 Time(s)
Audio files: 326
PostPosted: Tue Feb 14, 2017 3:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you, will have a look at it later today.
Audio files: 326
PostPosted: Tue Feb 14, 2017 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, it is not playable indeed, although there is actual content. Did a quick inspection on the file header and that does not look too unreasonable ... will need to try some other tricks to check it .. will come back on it.
Audio files: 326
PostPosted: Tue Feb 14, 2017 12:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, it looks like a valid wave file to me with a length of 639 ms .. the header looks fine, the file size of 111 kB matches an amount of audio of about that length ( 111000 * 1024)/ (4 * 44100) -> 644 ms. .. so more or less the same.
How long was this recording supposed to be?
Wobble
PostPosted: Tue Feb 14, 2017 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think I remember him saying about 1 or ½ a minute. Not 100% sure.
Audio files: 326
PostPosted: Thu Feb 16, 2017 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, well .. as the file seems completely valid I can draw no other conclusion than that all data was written to it and all data was saved .. so maybe there is an issue with measuring the amount of time .. but beats me, sorry.
Audio files: 326
PostPosted: Thu Feb 16, 2017 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
It was recorded by setting a duration? Or was it just stopped after a while - in the latter case - disk recording is not real time and the process priority is set back to background priority, which may cause things to be very slow in Wine.
Wobble
PostPosted: Fri Feb 17, 2017 1:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I talked to him, and he said he think he pressed run after instructing it to write to disk. So if he pressed run or something else before writing has finished could that have caused it?
Audio files: 326
PostPosted: Fri Feb 17, 2017 2:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, that would stop the recording.
