4 bugs
Page 1 of 1 [5 Posts]
Wobble
PostPosted: Thu Feb 16, 2017 10:02 pm    Post subject: 4 bugs
Subject description: with videos
Okay, I have found what appears to be some bugs:
1 - Sometimes when I double-click in the freq window to type in a freq, it locks up and wont let me type and modules sometimes start to move around when this happens. (see video #3)
2 - Sometimes when I go in menu to get a constant module, its not there even though its symbol is there the tooltip shows something else. Then I have to click the right slider next to that submenu then I works and I can get the module. (see video #2)
3 - Sometimes certain, or in the case of video #3 anyone, module refuses to be deleted. With del key or through context menu.
4 - After Video number 3, where I had to force close Wren, Wren would not start up again, before I shut down the NetMidi server.
Videos: https://www.youtube.com/watch?v=oG9CgJk1j-c&index=1&list=PLogi97V-ki0GE6QZtCX1FKPpcnB-4jjn2
(the videos are unlisted so cannot randomly be found through youtube)
PostPosted: Fri Feb 17, 2017 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, there are some bugs like that - badly reproducible though, so I did not really find a cause yet.
Also see : http://bluehell.electro-music.com/modules/#issues for some known issues.
PostPosted: Fri Feb 17, 2017 6:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice videos BTW.
I noticed that some questions came up during making the videos, there is some help available for modules - you can hit F1 on a selected module - in case that was not known.
There also is a FAQ ... http://bluehell.electro-music.com/modules/forums.html#faq which may have some useful hints.
Re. the ugly module colors .. they can of course be turned off .. or be made more subtle .. or you can make your own .. all module group colors can be changed. F3 brings you to the settings for that.
Wobble
PostPosted: Fri Feb 17, 2017 6:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you.
I was planning to make them public, but since they highlight many errors of the program maybe I shouldn't. Your program is very underexposed, I doubt many know it exists.
I know about F1. Smile
Yes, I figured out how to change colors, I have started to color code according to track. So for example all bass line modules will have same color, etc etc.
Wobble
PostPosted: Sat Feb 18, 2017 12:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay, I edited video #3 to remove most of the bugs. And made the videos public.
