gibrancurtiss
Posted: Mon Mar 13, 2017 10:38 am Post subject:
Pseudo sine wave good for general use or Drum kits. |
Hi guys
Made this little circuit to use with drum kits.
It's good from ~ 50hz to 200hz.
Pot 35 : Frequency
Pots 36 and 37 are to shape the wave the way you like. Or replace with trimpots to use a fixed shape.
If you want to crazy shape : I add a PWM diodes/pot on 40106...the wave gets cool.
Supply 9V + GND
I hope it should be useful for someone.
23.82 KB |
| Viewed: |
387 Time(s) |
260.79 KB |
| Viewed: |
348 Time(s) |
gibrancurtiss
Posted: Wed Mar 15, 2017 3:56 am Post subject:
nice little circuit, I am wondering what C62 does.
You could probably make an oscillator using 2 of the 4069 gates so you can do it with one chip.
An oscillator build with 2 inverters is also mores stable than a single schmitt trigger inverter one.
But if it will work might depend a bit on C62 since I assume the used 4069 is unbuffered. _________________ "My perf, it's full of holes!"
gibrancurtiss
Posted: Wed Mar 15, 2017 4:17 pm Post subject:
I was thinking about this circuit, but I see now it has the capacitor on the output so that wouldn't work for your circuit.
I don't know what the waveform on the other side of the cap looks though.
There is also this one which uses 3 gates but might be useful.
even if you would need 4 gates for it you could still do it with 1 chip. _________________ "My perf, it's full of holes!"
gibrancurtiss
Posted: Wed Mar 15, 2017 7:22 pm Post subject:
Hi Phobos.
Thank you again.
No problem if the last capacitor must be removed.
I'll try both circuits tomorrow!
Posted: Thu Mar 16, 2017 3:43 am Post subject:
The output of that first circuit is a squarewave. I thought the capacitor was at a different location so you could tap it
to get a triangle wave as with the 40106 oscillator, but that obviously doesn't work. As a I said I don't know how the
other side of the capacitor looks though, so maybe it is useful afterall. _________________ "My perf, it's full of holes!"
gibrancurtiss
