The Garden
Page 22 of 36 [883 Posts]
Goto page: Previous 1, 2, 3, ..., 20, 21, 22, 23, 24, ..., 34, 35, 36 Next
PostPosted: Sun Jun 11, 2023 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
some better photos of the Phacelia flower
They first appeared on my balcony in 2017 as a 'weed'.
* Spirals *
 Filesize:  200.83 KB
 Viewed:  143 Time(s)
 Filesize:  192.58 KB
 Viewed:  142 Time(s)
 Filesize:  183.57 KB
 Viewed:  142 Time(s)
PostPosted: Sun Jun 11, 2023 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
The tallest Lily, a 'golden Splendour', has now reached a height of roughly 130cm and flower buds are starting to appear.
I am curious how the timing is going to be between the different varieties, the Lilium Flore Pleno (Tiger lilies) and 'Mister Pistache'
don't appear to have flower buds yet but the 'Golden Splendour' might take longer to develop.
edit: correction; on closer inspection the 'Mister Pistache' Lilies do actually have some flowerbuds forming
for reference, those bamboo stakes are 150cm (about 15cm in the ground)
 Filesize:  357.18 KB
 Viewed:  163 Time(s)
 Filesize:  179.75 KB
 Viewed:  139 Time(s)
 Filesize:  196.82 KB
 Viewed:  150 Time(s)
PostPosted: Sun Jun 11, 2023 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm .. Phacelia tanacetifolia .. bee bread .. or bijenbrood in dutch .. i don't know it .. as in never seen it in the wild .. ah .. family of komkommerkruid ... Borago officinalis .. or just Borage .. did see that at times and ate it Smile
Nice plant!
PostPosted: Sun Jun 11, 2023 5:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
It always makes me a bit sad when the Pulmonaria (Lungwort) is done flowering though it was nice that it kept going for quite some time this year.
But now the leaves are starting to get larger again and it does have gorgeous foliage as well. It's not really in the best location for a shade
loving plant as it does get blasted with the full fury of the late afternoon sun, which can get quite hot at this time of the year.
It usually responds by going limp but once the sun is gone and it had a fresh drink it perks right back up.
The Hellebore that's in the same pot behaves similarly but has already produced a bunch of new leaves so I guess it's doing ok.
The foxgloves that are in a container next to it and get a lot more shade are also doing well, with some of the leaves measuring about 20cm.
I am not expecting any of those to flower this year but the larger they get now, the better the changes that I can get them though the winter.
I also planted one in the pot together with the Henbane and that one also appears to be happy.
Helleborus on the left, sunflower on the right
 Filesize:  377.27 KB
 Viewed:  166 Time(s)
 Filesize:  318.23 KB
 Viewed:  142 Time(s)
Foxglove peaking out from under the henbane.
There is also a small flower stalk (next to the sign) that belongs to another foxglove.
 Filesize:  347.92 KB
 Viewed:  150 Time(s)
an assortment of nightshades and some other plants, incl a morning glory seedling.
 Filesize:  319.65 KB
 Viewed:  157 Time(s)
I am actually not sure if I've seen it in the wild either. It is possible that it was part of a seedmix as I've had those (and still have)
for both bees and butterflies, but I am pretty sure it appeared in the same year as I grew that so it couldn't have self seeded yet.
I did see a happy bumblebee on it today, which also visited some other plants incl. henbane, foxgloves and dwarf goat's beard Very Happy
There is something that might be Borage growing in a pot but that would be Borago pygmaea, could also be Anchusa arvensis which
apparently is another kind of Borage or it's something else. I don't know if all of them are edible.
Audio files: 161
PostPosted: Tue Jun 13, 2023 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
quite bushey on the balcony now , nice gardening Pho Smile , liked the crow gathering vid Smile
PostPosted: Fri Jun 16, 2023 1:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks dave, it keeps getting greener.
Got anything growing on your end ? I knew you got some bulbs a while back but that was probably before the move.
PostPosted: Sun Jun 18, 2023 12:00 pm    Post subject: Crow fledglings Reply with quote  Mark this post and the followings unread
new crow videos
(more info in the video descriptions on youtube)
fledglings + parent (or older sibling)
 Filesize:  303.33 KB
 Viewed:  154 Time(s)
fledglings
 Filesize:  173.3 KB
 Viewed:  138 Time(s)
PostPosted: Sun Jun 18, 2023 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
some other wildlife in the form of ladybug larvae. They have been very effective at eradicating the aphids on my pepper plants.
 Filesize:  188.84 KB
 Viewed:  137 Time(s)
 Filesize:  123.2 KB
 Viewed:  141 Time(s)
it's a bit tricky to get a good photo of a moving leaf
 Filesize:  117.04 KB
 Viewed:  159 Time(s)
 Filesize:  104.36 KB
 Viewed:  148 Time(s)
PostPosted: Sun Jun 18, 2023 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Petunia is recovering from its recent haircut, a couple of strawberries are starting to ripen
and buckwheat has lots of tiny white flowers which results in more happy bumblebee noises.
 Filesize:  280.72 KB
 Viewed:  139 Time(s)
 Filesize:  237.29 KB
 Viewed:  137 Time(s)
 Filesize:  227.18 KB
 Viewed:  140 Time(s)
 Filesize:  204.96 KB
 Viewed:  155 Time(s)
 Filesize:  237.88 KB
 Viewed:  141 Time(s)
PostPosted: Sun Jun 18, 2023 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nigella orientalis is starting to get flowerbuds and the dwarf goats beard is getting beardier which also results in happy bumblebee noises.
On the day that the foxglove dropped its last flower a smaller flowerstalk on another plant started opening up.
Dahlia Red Skin II isn't getting very large (compared to the two other monsters) but has slowly been putting on some more foliage.
The Hosta is also staying small so far but I don't mind that at all.
 Filesize:  356 KB
 Viewed:  130 Time(s)
the Calamintha grandiflora in the background is also doing great
 Filesize:  249.34 KB
 Viewed:  140 Time(s)
spend foxglove flower stalk at the top, new flower stalk at the bottom
henbane in the foreground still growing on.
 Filesize:  338.89 KB
 Viewed:  149 Time(s)
 Filesize:  348.05 KB
 Viewed:  128 Time(s)
 Filesize:  216.76 KB
 Viewed:  132 Time(s)
PostPosted: Wed Jun 21, 2023 1:54 am    Post subject: Reply with quote  Mark this post and the followings unread
happy birthday
 Filesize:  123.08 KB
 Viewed:  129 Time(s)
 Filesize:  133.05 KB
 Viewed:  128 Time(s)
PostPosted: Wed Jun 21, 2023 10:04 am    Post subject: Reply with quote  Mark this post and the followings unread
The peculiar flowers of the Nigella orientalis 'Transformer'
 Filesize:  398.08 KB
 Viewed:  130 Time(s)
 Filesize:  166.25 KB
 Viewed:  134 Time(s)
 Filesize:  184.84 KB
 Viewed:  136 Time(s)
PostPosted: Wed Jun 21, 2023 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
There are also some flowers on some of the alpine plants
 Filesize:  317.87 KB
 Viewed:  143 Time(s)
 Filesize:  431.29 KB
 Viewed:  147 Time(s)
 Filesize:  275.5 KB
 Viewed:  144 Time(s)
 Filesize:  125.86 KB
 Viewed:  119 Time(s)
PostPosted: Wed Jun 21, 2023 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
happy birthday
Cool
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Jun 23, 2023 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
 Filesize:  157.44 KB
 Viewed:  135 Time(s)
PostPosted: Sat Jun 24, 2023 3:07 am    Post subject: Reply with quote  Mark this post and the followings unread
curious wildlife you got there.
my trees aren't big enough yet but I do already have a hammock.
PostPosted: Fri Jun 30, 2023 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
The tri-cotyledon sunflower has grown up and is now producing multiple flower heads. (I counted 5 so far)
Lion's Tail has also started to pick up in size and is now ±40cm. Judging by its leaves it's actually Leonotis nepetifolia not Leonotis leonurus.
I am not expecting flowers this year but it's possible. It can be grown as a perrenial and even an evergreen but probably not in this climate.
As a matter of fact I will have to keep an eye on it during autumn/winter as it is not very cold resistant.
The Lillies have still grown a bit, with the tallest at ±150cm but most of the energy is now being diverted to the flowerbuds,
which are slowly starting to change color.
 Filesize:  191.94 KB
 Viewed:  134 Time(s)
 Filesize:  188.92 KB
 Viewed:  135 Time(s)
 Filesize:  260.59 KB
 Viewed:  124 Time(s)
 Filesize:  185.2 KB
 Viewed:  118 Time(s)
PostPosted: Mon Jul 03, 2023 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
"Green is the colour of her kind"
 Filesize:  396.92 KB
 Viewed:  150 Time(s)
 Filesize:  369.09 KB
 Viewed:  137 Time(s)
 Filesize:  419.22 KB
 Viewed:  144 Time(s)
catnip
 Filesize:  299.16 KB
 Viewed:  131 Time(s)
PostPosted: Mon Jul 03, 2023 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
first Lily is opening today. Razz
 Filesize:  293.48 KB
 Viewed:  138 Time(s)
 Filesize:  267.96 KB
 Viewed:  144 Time(s)
 Filesize:  309.83 KB
 Viewed:  137 Time(s)
PostPosted: Tue Jul 04, 2023 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
not just a feast for the eyes, also for the nose as they are very scented.
 Filesize:  266.33 KB
 Viewed:  139 Time(s)
 Filesize:  198.68 KB
 Viewed:  140 Time(s)
PostPosted: Tue Jul 04, 2023 11:19 am    Post subject: Reply with quote  Mark this post and the followings unread
[..] as they are very scented.
Especially that last picture. I can smell it from here Exclamation
Hope tomorrow's wind will not ruin them Shocked
PostPosted: Thu Jul 06, 2023 1:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very pretty flowers! Any chance of a zoomed in photo to show your balcony from the outside? (Cropping out your neighbours of course)
PostPosted: Sat Jul 08, 2023 1:07 am    Post subject: Reply with quote  Mark this post and the followings unread
best I can do
 Filesize:  3.16 MB
 Viewed:  147 Time(s)
PostPosted: Sat Jul 08, 2023 1:11 am    Post subject: Reply with quote  Mark this post and the followings unread
and here's a time lapse showing the amount of sun it's getting at this time of the year.
https://youtu.be/yth6G5flYBE
